Swapping A 4.2 ????
Old Mar 14, 2000 | 07:27 PM
ccla's Avatar
Post Swapping A 4.2 ????
If I wanted to swap my 4.2 out with something bigger, what could I shove in there???? 4.6?? 5.4??? I dont wanna have to change the tranny. ( 5 speed ) I'm just throwing around Ideas. Any other crate motors that would be a fairly easy swap?? what could I expect to pay to do this??
98 F150 2WD,Bright Red, Regular Cab, 4.2, 3.55, 5 Speed, Superchip, 2 Superchip Decals (I Think They Add 5 HP Each), 3 Inch Bullseye Lift Spindles, 3" Body Lift, 1" Coil Spacers, 3" Blocks In Rear,Manik Grill Guard,Nerf Bars, Vent Visors,Air Box Mod, Fog Lights Mounted In Front Air Dam ,4 Kc DayLighters, Back Up Lights, Alpine CD Player, 2 Kenwood Amps, 10 Inch MTX Blue Thunder SubWoofer, Tinted Windows. 35" BFGOODRICH ALL TERRAIN KO'S Mounted on 16.5x9.75 American Racing Baja Rims
..........."IF YOU CAN'T STOP, SMILE AS YOU GO UNDER"...........
'00 Toyota Celica GT( Wife's Car )
Pics @ http://www.angelfire.com/la2/ccla/
[This message has been edited by ccla (edited 03-14-2000).]
Old Mar 14, 2000 | 09:16 PM
fast46triton's Avatar
Post
A 4.6l or 5.4l could fit in there, with some adjustments. I dont know much on engines and stuff as of now, but it would cost more than 3000$ for the motor itself.
Old Mar 14, 2000 | 10:40 PM
4byFord's Avatar
Post
I saw a classified for a 4.6L with Transmission + computer + superchip and everything for 2000 bucks (what a deal)! The guy actually wants to put a 302 in there??
ccla, I think the job will be a big one, don't forget that the computer will not be the same, and maybe the wiring harnesses? You can fit a carb fead 460 in their, I saw this on the net somewhere. The guy also put a solid axle in the front.
It just might be cheaper to put a supercharger on the 4.2L, check the boards their is someone that put a SCharger on his 4.2L.
1997 4x4 XLT 4.2l ORP 5-speed
For more details and pics please see my site...Thanks
www.eph1fifty.cjb.net
[This message has been edited by 4byFord (edited 03-14-2000).]
Old Mar 15, 2000 | 09:17 AM
Tenderpaw's Avatar
Post
You can do the swap but you will need the engine, transmission, computer, wiring harness from a V8 truck. The V6 trans will not bolt up to the V8 because the bellhousings are different. (the V6 uses the same bellhousing as a 5.0, believe it or not). Be sure the engine you buy has all of the accessories with it (A/C compressor, etc..)
2000 Expedition XLT, 5.4, 3.31 Rear axle, 4R100, no other mods
