4.6L Engine Oil Leak Fixed
Old Mar 12, 2000 | 09:12 PM
Kelly's Avatar
Question 4.6L Engine Oil Leak Fixed
I recently took my truck to the dealer for some work. One of the problems was that the hoses leading to the remote oil filter were leaking oil where the metal connector joins to the rubber hose.
Has anyone else had this same problem? All they did was replace both hoses to fix it.
Kelly
for more info on my truck, just click the link below and browse around.
http://www.fordf150.net
Old Mar 13, 2000 | 09:43 AM
Tina's Avatar
Cool
Did replacing the hoses fix the problem?? Or do you think ford should have just replaced the connectors?? Or maybe just tightened them up a bit more???
Some of us have had new trucks with loose parts, bolts, connectors, ect. that just needed to be tightened down to fix the problem. You should even check things like tire pressure, Ford sometimes forgets to do the simple things!!
2000 F250 Crew Cab 4x2 6 speed Diesel XLT Super Duty, Woodland Green
Power Mirrors, 3.73 LS, Captains Chairs, ARE tonneau top, mud flaps
Trailer tow Pkg, Class IV hitch, sliding rear window, running boards
rear privacy glass, 265/75/16 AS OWL tires, am/fm/cassette/cd
Clarion APA 5240 amp, Memphis speakers:Components front, 5x7 rear, 10"sub
SuperChip, Stepshields, Ventshields on windows, rubber bed mat
rugged liner bedliner on tailgate
unaFORDable (decal on tailgate)
Old Mar 13, 2000 | 01:33 PM
Kelly's Avatar
Post
Replacing the hoses fixed the problem.
The hoses are part metal tubing, and part rubber tubing. It wasn't actually leaking from the connection (i.e. end of hose), but where the rubber hose & metal tube joined. There are no connectors there.
It's kind of hard to explain.
Kelly
