noisy lifters when starting
Old Mar 6, 2000 | 05:14 PM
Nelson's Avatar
Unhappy noisy lifters when starting
Even though I use 5-30 and a motorcraft oil filter, I almost always hear a lifter tapping noise for the first 10 seconds at the morning startup.
The truck has 9k on it, and I am concerned.
Should this been checked at the dealer, or just lived with?
Sounds kind of trashy.
Old Mar 6, 2000 | 05:26 PM
andrew s's Avatar
Post
Use a motorcraft filter. search other threads, this issue has been researched by others. motorcraft has backflow valve that has solved problem for about 9 out of 10 with this prob..
Old Mar 7, 2000 | 01:14 AM
V10 man's Avatar
Post
You almost never hear about lifter noise... it's always piston slap....
Old Mar 7, 2000 | 07:05 AM
Rand's Avatar
Post
Thats what I thought my noise was... UNTIL I FOUND OUT ABOUT PISTON SLAP!!!!!!!!
I had the 5.4 replaced at 49K FREE OF CHARGE!
Might want to have that checked!
Old Mar 7, 2000 | 04:56 PM
Dustoff's Avatar
Post
With only 9K miles on it..I would have your dealer look at it. It can't hurt.
Many of us experienced valve chatter at start up when a FRAM filter was used (I used a FRAM one time). I have never had any kind of valve chatter like you have described in either the 98 5.4L F-150 I had or my new truck.
2000 F-150 XLT, 4x2, 5.4L Supercab, Styleside, Black with silver two-tone, 3.55, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Mar 7, 2000 | 04:57 PM
Dustoff's Avatar
Post
Is start up the only time you hear this chatter? Do you hear it during acceleration or going down the road???
Old Mar 7, 2000 | 06:16 PM
LoNE WoLF's Avatar
Angry
Howdy Nelson,
My 2000 F-150 makes a racket also when it starts up. Sounds just like valve train noise. Once the engine warms up the noise ceases. It seems to last for a couple of miniutes. I have 4,300 miles on mine and it has done it from day one. I just had the oil changed, and was hopping that I got a hold of a defective Motorcraft filter, no luck. Ive used Motorcraft filters and 5W-30 exclusively. What year is your truck?...
2000 F-150 Lariat, Flareside, Black, SC, FOxFO, 5.4L, 3.55, Garmin Street Pilot Color GPS
Old Mar 7, 2000 | 11:45 PM
Nelson's Avatar
Post
My 99 f150 4.6 is a romeo- and I have heard a rattle the marbles-like ticking valvetrain chatter since new.
It only happens in the morning, but it has not been below freezing here all winter.
If I back up , I hear a (piston slap?) slight knocking . This will stop within a few minutes.
Always used the 5-30w oil, Motorcraft filter. I tried the Fram - it ran noisier still.
Its almost like hearing a mechanical fuel pump tapping like crazy against an eccentric, but I suppose it might be a defective hydraulic lifter?
Anyone know of a good (online) cutaway of the vaunted Triton?
Old Mar 8, 2000 | 06:20 PM
LoNE WoLF's Avatar
Arrow
Nelson,
I don't think these engines have any lifters, they are of the overhead cam design.
Old Mar 8, 2000 | 06:29 PM
knt's Avatar
knt
Lightbulb
I thought I had lifter noise also, wrong!!! I had the slap.
Old Mar 8, 2000 | 11:10 PM
msparks's Avatar
Post
I have the lifter noise, I probably would not even notice it, except that I'm worried about piston slap.
When I was running 5w30 it would last around 5 seconds.
I now run 0w30 and it will last 2-3 seconds.
I don't think that its piston slap, because my understanding is that piston slap will last 30 seconds or longer. I now have 20k on the truck and it still does it.
Lube-Direct
Old Mar 9, 2000 | 09:22 AM
TripleD's Avatar
Cool
Ok guys, yall had me worried. I went out to check for noise this morning inside and outside of cab. Absolutely no noise inside of cab and a slight valvetrain noise outside with the hood up. I did experince alot more noise under hood @ 12k to 15k, but it has quiet drastically.
I have 39k at this time and using 5w-30 oil and Wix oil filter. Change oil and filter every 6k.
www.synerlec.com
[This message has been edited by TripleD (edited 03-09-2000).]
Old Mar 9, 2000 | 07:14 PM
Nelson's Avatar
Post
I think the Triton may use hydraulic lifters-
since I know Nissan did on their OHC six at one point.
The sound reminds me of a slant six I owned that needed to pump up the hydraulic lifter before it quieted down.
