bad ground?
Old Oct 30, 2001 | 03:02 PM
earnhardt3's Avatar
Lightbulb bad ground?
If i hit a hard bump the engine will cut off,and just maybe after 5min. it will start up and run fine.What do u think
Old Oct 30, 2001 | 06:02 PM
98 4x4Flareside's Avatar
need more info
Some questions for you:
What year/model/type of engine?
When you hit the bump, does it immediately die or still run for a few seconds...?
What mods do you have?
Although it is tough to help you w/o those answered, a few things come to mind:
If you have a distributor, that is the first thing that occured to me. If u have one, i would check on the spark plug wires and the rotor.
Intermittent ground is very possible. I have seen a bad ground manifest as a buttload of different symtoms and have learned to never to take a ground for granted. Go ahead and unscrew the grounds you can find and clean/sand the ground area and terminals and reconnect.
If you have a multimeter and a Haynes/Chilton's, check the solenoid.
Last, I would check the alternator (belt at proper tension, securely bolted/immovable, maybe bench tested at Advance Auto Parts <free>).
Hope this helps for now...
