BLOWN OUT FROST PLUG!!!!!!
Old Feb 27, 2000 | 08:43 PM
Neal's Avatar
Cool BLOWN OUT FROST PLUG!!!!!!
HI!... Well guys today when I was sitting at a red light my truck started to steam everywhere. I managed to drive it to a buddy's house. I found out that my block heater frost plug had blown out and was hanging there. Apparently the rubber "O" ring got torn and caused it to fall out. So I called the FORD emergency # and a flat bed tow truck showed up. I had it towed to my dealer and that is where it sits at this moment. Has anyone else had this problem too.I know a lot of LIGHTNING's around here have had the same problems, but this is the first regular F-150 that I have heard of with this problem. Any help on this problem would be great.
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, **** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, AUTOMETER guage pod and tranny temp guage, custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP.
FUTURE MODS : JBA headers, ASP power pulleys, twin electric fans, traction bars, BAUMANN ENGINEERING shift kit, POWERAID spacer, AUTO METER oil preasure/ engine temp PHANTOM GUAGES and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 310H.P / 405ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
Old Feb 27, 2000 | 10:26 PM
Ford man's Avatar
Banned
Post
Not that big of a deal, they go out on old and new engines fairly regularly. I'dve hiked it down to the nearest parts house and bought a freeze plug kit and some antifreeze and been on my way.
Old Feb 27, 2000 | 10:53 PM
bggroth's Avatar
Post
Neal,
Sounds to me that whoeveer is installing these frost plug heaters is screwing up. The lightnings don't come with factory installed frost plug heater so if they are comming out it is not fords fault.
99 red lightening,psp filter kit,Superchip, bassani complete system
2-2000 arctic cat zr440 snopro's
built 5-26-99, #1610
2000 super duty v10
Arctic cat 400 4x4
99 chev c1500 pickup
2000 red Lightning on order 2-14-00
Old Feb 27, 2000 | 11:23 PM
Neal's Avatar
Cool
HI!... FORDMAN : Thats exactly what I did. Put a new one in and then drove 3 blocks and it blew out again! So the way I see it, the dealer can deal with it now!
Old Feb 28, 2000 | 05:58 AM
Ford man's Avatar
Banned
Post
What did you do wrong? A freeze plug doesn't have any moving parts.
Old Feb 28, 2000 | 08:13 AM
Ford man's Avatar
Banned
Post
Let me append that, sometimes it's possible to install a freeze plug that's slightly undersize or not get one fully seated and, boom, out it comes. It's also possible to have a freeze plug hole honed slightly oversize so that it's nigh impossible to get a freeze plug to seat properly. Had that happen on a rebuilt 300 c.i.d. six once. The hole was honed oversize AND had a gouge in a small area of the seating surface. Wound up filling in the gouge (an area about the size of a ball point pen tip) with J-B Weld and coating the freeze plug with Permatex 2C. Drove it for three more years with nary a leak, heard it's somewhere around Longview, Texas still going with no leaks. Seen it happen on a few NEW engines, too. Not that big of a deal, but if I can avoid a dealer service department, I will.
Old Feb 28, 2000 | 10:30 PM
Neal's Avatar
Cool
Hi!... FORDMAN : The block heater frost plug has many moving parts. The "O" ring on mine was torn slightly when it was installed at the factory. That is what caused it to blow out. I picked it up from the dealer today and the mechanic told me that they have seen this happen many times on the 5.4 and 4.6 engines. They installed a new block heater frost plug, right this time!
