4.2 FINALLY Supercharged (was not fun)
Old Dec 19, 1999 | 09:06 PM
XanMan's Avatar
Post 4.2 FINALLY Supercharged (was not fun)
I just wanted to update everybody on my project.It did NOT go as planned.
1)The major problem was finding a belt and tensioner.
2)The next biggest obstacle was the pressure tube.On my truck it was really short with a 2"straight piece then a 45% then 2"piece then a 90% all bent out of a single 3"pipe.
3)The final problem was relocating the powersteering reservior one new bracket later I was done.
But It was DEFINITELY worth all the long nights (5 to be exact).It feels like driving a sportscar.And thats at 3/4 throttle per Mike Troyer's advice,He said not to open it up until my Superchip gets here.I cant wait.
99 Black F150 4x4 4.2
powerdyne SC (7lbs.boost)
24 psi.high flow fuel injectors
True duel exhaust w/Flowmasters(2 1/2 in. pipe)
custom programed Superchip(in the mail hopefully)
All black factory sport package.
GTO smoke headlight&tailight covers
limo tint
Mods. to come 4.30 gears
Old Dec 19, 1999 | 09:13 PM
Frank S's Avatar
Post
That sounds great! If there was some way you could reproduce all the custom parts there are people on this board that would be real interested(me included)! I'd like to see the times that puppy will run now.
'97 XLT Reg. Cab, 4.2V6, 5spd, Superchipped, K&N Air Filter, Lund Deflector, Dash Mat, MagnaFlow Muffler, Hellwig Rear Sway Bar, Edelbrock Shocks, Duraliner, Extang Saber Tonneau, Bell-Tech 2" Rear Drop, Amer. Rac. Atlas Wheels Clad in 275/60/17 Eagle GTII. Likes straightaways, loves twisties.
Old Dec 20, 1999 | 02:30 PM
HotRodSix's Avatar
Post
XanMan - I understand you have a Powerdyne supercharger. Which kit did you use?
HotRodSix
'98 STX Flairside 4.2L
Best 1/4: 16.26 sec. @ 84.4 mph
Dyno: 180 rwhp / 228 ft-lb
Old Dec 20, 1999 | 08:44 PM
Darin's Avatar
Exclamation
How about posting some pics?
99 F150 XLT Silver 2WD S/C 4.2 5-speed, Pioneer DEH P4000, Superchip, Flowmaster muffler // Rear door switch guards - check them out at http://www.geocities.com/motorcity/show/5031
Old Dec 20, 1999 | 09:39 PM
Frank S's Avatar
Post
Help us! We need MORE POWER! Kicking some V8 butt sounds real good!(shovies preferably)
Old Dec 20, 1999 | 10:45 PM
XanMan's Avatar
Talking
HotRodSix,Franks,Darin,
These are the parts that I got from Powerdyne
1)S/C PD. 6lb. satin w/straight volute 1,550
2)Elbow 90 Deg. long plastic (2) 22.00- 44.00
3)Silicone tube 3 1/2 x 2 (2) 13.00- 26.00
4)Silicone tube 3" (2) 13.00- 26.00
5)Hose flex 3 1/2 x 24" (1) 25.00
6)Crankshaft pulley (1) 24.75
These are the parts that I got elsewhere
1)24psi. fuel injectors (Jegs) and yes I had to buy an 8 pack 208.00 plus shipping
2)intake plenum gasket
3)3 8mm x 130mm bolts 9.50
4)3 8mm x 80mm bolts 6.00
5)5 rib 65inch belt Dayco 21.00
6)Spring loaded belt tensioner 65.00 (really tight spot so I had no choice in the price but they are as cheap as 15.00 but they were all too big)
7)The main bracket made from wood templates.Finished out of 1/4" steel (one piece) 208.00
8)powersteering resivoir bracket 3/16" steel 30.00
9)custom intake air box to recycle pcv air and run K&N filter with 5" water resistant intake
10)pressure pipe was free (about time)
The bracket mounts over the air conditioning using the 3 8mm x130mm bolts w/3/4" spacers.
The 4th bolt goes in the old powersteering bracket hole (front one).
This is a very strong setup and there is no vibration at all!
The pulley from Powerdyne fits perfectly in the crank pulley but we have 3 holes and the pulley has 4 so they have to be drilled (easy) I also put welds at the points where the new pulley touches the crank pulley kind of like a gear so the bolts have no stress on them. These bolts 8mm x 80mm.
Don't forget that you have to get a Superchip custom programed to control the new injectors and the mass air flow sensor.
Well sorry if this is kind of long but its hard to explain,I hope this helps.Let me know if I can help more.
Oh by the way I put 220 miles on it today,Just couldn't stop driving and no problems.
I took tons of pictures but I don't have a scanner.If you have any ideas let me know.
limo tint
Old Dec 20, 1999 | 11:09 PM
ponysix8's Avatar
Post
happy to hear it worked out for you. So should us other 4.2L owners contact Powerdyne or have you found the name and number of the place you got the supercharger from?
Old Dec 20, 1999 | 11:58 PM
XanMan's Avatar
Thumbs up
ponysix8,
I got all the Powerdyne parts from Powerdyne.Just ask for sam 1-661-723-2800 and tell him Josh from North Carolina referred you.I also left out in my last post that I did not use the pulley that he sent me,he gave me the number of a performance shop that sells oversize pulleys thats what gave me about 7lbs. of boost.The one they send is 7" the one I have on my truck is 71/4" they both have the same inside diameter.So either one you choose will work.
limo tint
Old Dec 21, 1999 | 07:47 AM
HotRodSix's Avatar
Post
XanMan - Thanks for the input. Your truck sounds awesome!!
HotRodSix
Old Dec 21, 1999 | 01:39 PM
Darin's Avatar
Post
XanMan, You could go to a Kinkos to get the pictures scanned.
Old Dec 21, 1999 | 10:12 PM
XanMan's Avatar
Talking
Darin,
Do they scan them to a floppy or a disc? And i'm not sure how to get them posted on this thread.If anybody can help me I would appreciate it.
Does anybody have 0-60 times on their 4.2?I would like to compare them with my truck the way it is (no superchip and not exceeding 4500rpm's due to possible leaning out at WOT)Please list all mods. if you can.Thanks for your intrest.
limo tint
Old Dec 22, 1999 | 06:12 PM
Frank S's Avatar
Thumbs up
XanMan: Thanks for the info. If you can get some pics up sometime it would be greatly appreciated.
Old Dec 22, 1999 | 08:57 PM
DirtSlinger's Avatar
Post
Hey XanMan,
CONGRATS on your new huffer!! I can definately relate to a difficult process..and it being worth it in the end. Ive been building a street/strip car for alittle over 2 years now. Trial and error is an unfortunate but needed process...but the pride of doing yourself (and kickin a$$ with it) is well worth it!
Best of luck with your 6cyl sleeper
DS
Old Dec 22, 1999 | 09:19 PM
XanMan's Avatar
Unhappy
Well I just got off the phone with Jay at Superchips and he had bad news for me.They told me that they can't run my chip through because they don't have a baseline to start with on the fuel system for a SC 4.2liter.He said that they have to get the same truck with the same pcu punch on the dyno.And that won't be til after the first of the year.(what a drag).So I guess I have two more weeks babying it.
DirtSlinger,what kind of car are you building? And your right on the trial & error,but the rewards are worth it
limo tint
Old Dec 26, 1999 | 12:01 AM
98F150xlt4x446's Avatar
Post
god how stupid. why would you want to supercharge a 4.2 V6????? That engine sucks. You should have gotten a 5.4 and supercharged that. you either enjoy wasting your money, or your really stupid. why don't you send your money this way, instead of blowing it on a supercharger for 4.2
