sticking thorttle
sticking thorttle
Just wondering if anyone had any problem with their thorttle sticking on the 4.6 engine?
I have stepped down on the gas pedal to pass and it had stuck. I really had to kick it hard to get it to return.
I have a 1997 F150 with the 4.6 engine,4x4 with 14000 miles on it.
I would appreciate any thougts on the problem.
Boom
This happened to me once last week. The truck sat outside all day in single digit temp's. Not sure if it froze or what. If it happens again it will certainly make a visit to the dealer.
Jeff
1999 F150 Lariat
Reg cab Short box Styleside
5.4L 3.55ls
Deep Wedgwood Blue/Silver
Lund Interceptor hood shield, VentVisors, Class III hitch, Ford molded mud guards, soft tonneau, factory CD with changer (thanks Dusty), tinted windows
Menasha, WI
http://www.fortunecity.com/silversto...ton54home.html
Jeff
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
Have you tried to clean and lube the exposed portion of the cable? I would also clean the throttle body at the same time. This would most likley be the same course of action that the dealer would take,and it will save the hassle of going there. If that does not work then have the dealer give it a try.
Bob P.
99 F-150 XLT 120" w/b
5.4L w/ASP underdrive pulleys, Custom Superchip, Airaid system,Poweraid TB spacer,Borla Turbo muffler, and 2" Drop shackles.
Bob P.
Do you have floor mats? Especially after market mats? If so, chances are the bottom of your pedal is getting stuck on the mat. It's a common enough problem that if you have a Lariat, the mats are held in place with a little hook in the floor.
Move your floor mat back. It's too far forward and the pedal is getting stuck on it.
I was at a dealer last night getting a key cut ( santa got me a new remote start) and he said it was impossiable that ford had fixed that problem, my truck had ben sitting about a hour now (looking through the accssory catalog) went out and it was froze. He talked with his tech thaey have no fixes for it at this time. My truck has about 3300 miles on it the cable is free out of dirt they wil call next week they are going to cal the tech line to find a cure > Believe it when i see it. P.S. they use citgo oil 10-30 for all oil changes they where not aware of the probems with they heaver oil!!!!
2000 blk xlt f150 4x4 orp pkg 5.4 3.55 ls herculiner , A.R.E. cap
Throttle getting stuck happened to me too. And guess what it wasn't cold out more like 70 degrees. So throw that on the burner.
1998 F150 XLT Reg. Cab, STX, White, 4.2 v6, 4x2, K&N, 3.55, Manik grill gaurd, **** Cepek 100 watt driving lamps, Kenwood mask CD-player, drop hitch, Ford hitch insert, 16x8 Atlas rims w/ 285/75/16 BFG All-Terrains KO all on a 3 inch bullseye spindles. Looks like a serious truck now
Gmptj,
Your profile says you have 373's are you sure because i have a 2000 also and they no longer offer 373's 3.55's only with the 5.4
I wanted 373's i would have had to get a 99.
are they after market???
I had my truck at the dealer last week and had them check this. They ordered a new throttle body. Not sure if they are just throwing parts at it or what, but it's worse since they looked at it. Hopefully the new part will be here soon.
Jeff
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
Jeff
1999 F150 Lariat
5.4L 3.55ls
Menasha, WI
