1997 f150 lariat engine swap
Hello everyone! New here an glad. I have an F150 Lariat with a Romeo engine. Is it interchangeable with a 12/03 F150 Triton Romeo engine. I got it with everything from manifold to wire harness. The only thing I didn’t get was the computer, radiator, an a/c compressor. I even took the aluminum intake. I took it ALL, just in case. Will it fit my 1997? Do I also need the computer? Please help!?
don’t swap the ecm
the PI 4.6 swap is a good choice
Thank you so much for responding Stoffer. I was worried I had wasted my money. Thanks! So to be really clear; I am to leave my engine computer on my truck and use it with my 2004 engine Instead of using the computer on the 2004 f150?
Oh, it's a 2004 engine? Did it come with a conventional or electronic throttle body?
Note - you CANNOT use the 1997 intake or exhaust manifolds on the 2004 engine. You cannot use the 2004 computer.
2004 used electronic, 2003 and earlier used cable. You will have to use the 1997 throttle body on the 2004 manifold.
Another thought - I believe the 1997 used separate coolant temp and head temp sensors, 2004 only has head temp. This may require computer reprogramming.
OP, "Is it interchangeable with a 12/03 F150 Triton Romeo engine."
Note - you CANNOT use the 1997 intake or exhaust manifolds on the 2004 engine. You cannot use the 2004 computer.[/QUOTE]
2003, or 2004?
2004 a 3V eng was used, UNLESS(!!!) your '04 is a Heritage" model... which was an excuse to use up old '03 2V eng parts. What else was 03 & carries forward to the Heritage model, or '04, is above my paygrade, along with most stuff.
2003, or 2004?
