5.4L 3V problems
Old Dec 8, 2020 | 09:11 PM
Overit's Avatar
5.4L 3V problems
Just recently rebuilt a 5.4 3v for my 2005 f150 ran fine for a week but it suddenly started running rough fixed a few codes but for some reason can not shake power issues. It is sluggish on take off then it runs great between shifting gears but when it shifts the truck bogs down and pops. Any idea what i could do to fix this issue
Old Dec 9, 2020 | 09:22 AM
Roadie's Avatar
What brand of phasers did you use?
Old Dec 9, 2020 | 09:46 AM
Overit's Avatar
didnt use aftermarket I bought the kit from ford but had to go aftermarket for the Oil pump
Old Dec 9, 2020 | 10:21 AM
That's what we recommend - OEM timing components and a Melling oil pump, sounds like you did it right.
Old Dec 9, 2020 | 11:21 AM
Can you post the exact codes? Please.
Old Dec 12, 2020 | 07:53 PM
Overit's Avatar
Ok hooked it to live data and the timing is over retarding on the throttle instead of advancing. Any suggestions?
Old Dec 12, 2020 | 11:16 PM
Does it return a P-code?
Old Dec 13, 2020 | 09:10 PM
Overit's Avatar
I didnt think to look the codes that show is crankshaft sensor
Old Dec 13, 2020 | 10:51 PM
What is the numeric P-code?
