P0315 code
Old Jul 20, 2020 | 03:59 PM
Matt Sal's Avatar
P0315 code
I have a 03 f150 super crew 4.6 engine 174k on the dash I literally just got it about 2 weeks ago ,
well upon purchasing there was no check engine light on at all ( not sure if it was reset or what ) I started noticing a slight vibration here and there when the truck was slowing down ( no brakes applied) so I thought maybe the drive shaft was acting up and after doing some research . Pulled the drive shaft down and inspected it, looked ok to me u joints where fine no play , so I applied some grease to the slip yoke and put it back on , test drove it the next day and the check engine light comes on , And this is only after putting about a 100 miles total on it since I got it . Got the code scanned and it said p0315 cps not learning . I asked the people who I got the truck from has any work been done to the truck they said no but before and cps code has popped up before but it went away , I never told them the code that showed up either , so where can I go from there ? Sorry for the long paragraph but I needed to put this information in to state my issue ? Thanks
Old Jul 20, 2020 | 05:23 PM
Roadie's Avatar
Read this, it may help you figure it out.
https://www.obd-codes.com/p0315
Old Jul 20, 2020 | 08:51 PM
Matt Sal's Avatar
I’ll check it out I tried doing the re learning by driving it up to 65 and letting it drop to 30 without the brakes but not sure if it worked because the light came back on after I let the cable off the battery for a bit , was hoping someone has experienced this situation before
Old Jul 21, 2020 | 08:55 PM
Matt Sal's Avatar
Took it to a mechanic and he cleared to the code and wanted to see if it would comeback on , drove it about 20 minutes up the road and it started making this noise right here . ( see video link )
it wasn’t making this noise before and it randomly just started
Any help on that the noise could be ?
Old Jul 21, 2020 | 10:01 PM
That sounds like lifters.
Old Jul 21, 2020 | 10:40 PM
Roadie's Avatar
Perhaps you should watch this video.
Old Jul 21, 2020 | 10:47 PM
Matt Sal's Avatar
https://www.youtube.com/watch?v=ChUcIwikVhU
thanks for the reply taking a look at the video now
this just randomly started happening so I’m wondering if the previous owner put something in the engine so it wouldn’t make the noise for a while ? Or is that even possible?
Old Jul 21, 2020 | 10:55 PM
That video doesn't apply to the 4.6 2 valve.
Sounds like my son in law's 98 with a 4.6 when a few lifters collapsed. You won't really know what's going on till you pull the valve covers and front cover. If you like the truck, it may be time to look into a rebuild. He sold the truck for $1800.
Old Jul 22, 2020 | 06:26 AM
Matt Sal's Avatar
😬 I hope not I literally just got the truck and paid a decent amount for it and really don’t want invest a crazy amount into it all , well I just went outside and crunk it on a cold start and it’s not doing it 🤔 maybe it’s something that happens when the engine gets warmed up and the oil gets hot ?
Old Jul 22, 2020 | 09:14 AM
Roadie's Avatar
That video may or may not apply. It still has OHC and cam followers I presume?
Maybe you should try this?
Old Aug 2, 2020 | 09:27 PM
Matt Sal's Avatar
Sorry for not updating , I woke up the next day and the truck wasn’t making the noise . So I drove it a few days and the check engine light randomly went off , it’s been over a week light came back on for the same code and it’s making the noise again 😔
Old Aug 18, 2020 | 06:28 PM
Matt Sal's Avatar
Anyone know anything about the p0315 code ? I’ve looked into it and I haven’t find any answers about it being fixed or anything
Old Aug 18, 2020 | 06:48 PM
Did you read the whole article linked in post #2?
Old Aug 18, 2020 | 07:26 PM
Matt Sal's Avatar
just went back over it I’m guessing ima take it in and get it checked out , I’ve done the drive test and nothing , is the crankshaft position sensor on the front of the engine on the 4.6 ?
Old Aug 18, 2020 | 09:07 PM
It's located on the right lower side of the timing chain cover, behind the air conditioning compressor.
