5.4 3v has a knocking sound
Old May 7, 2020 | 02:20 PM
Pureglass's Avatar
I just replaced the oil pump, timing chains, cam phaser deletes, cam followers, lash adjusters, I use mobile 1 synthetic 5-20 and motorcraft filter. Finished it up truck sounded great driver about 200-300 miles and boom now sounds like an old 7.3 at idle. Not just start up.
Old May 7, 2020 | 03:57 PM
Roadie's Avatar
Did you use the high volume Melling pump that everyone recommends?
Try some 10W40 and see if that helps.
Old May 7, 2020 | 04:30 PM
Pureglass's Avatar
yes I did use high volume pump
Old May 7, 2020 | 05:21 PM
Pureglass's Avatar
I pulled the valve covers back off and turned the engine over by hand. One spot the driver side cam make a clunk.
Old May 15, 2020 | 07:59 AM
RedFox93's Avatar
You Tube
I had same knocking issues....tensioner had broke and chain was slapping front cover. Used the 4 part series on YouTube that had all links to parts, torque specs ect. FLAWLESS! You must use all Ford parts, high volume oil pump. Yrs it is a little more cost but well worth it when it comes to frustration. These are the links
Prt#1
Prt#2
Prt#3
Prt#4
