Main Bearing caps
Old Mar 30, 2020 | 02:44 PM
tourbus's Avatar
Angry Main Bearing caps
So after i replaced my engine, timing chains and guides, phasers, it dropped a valve and damaged the head and cylinder wall. I still have the block from the original engine but no main caps. question is can i use the main caps from one 5.4 in another 5.4. Im on a tight budget and cant afford another engine.
Old Mar 30, 2020 | 03:10 PM
Roadie's Avatar
Possibly. The caps would have to be machined to fit and have to be align bored on the different block. I'm speaking from knowledge gained working on a 1972 Pontiac 455. Your engine may be different? On the 455, the cap was ground on the ends to make it a tighter fit and then align bored through all of the caps.
Old Mar 30, 2020 | 03:12 PM
Please do not take this as fact. I believe you can, but they must be retained in the same physical position in the block, front to rear.
