Need help 03 f150 5.4L P0174 code.
Old Feb 10, 2020 | 10:56 PM
Txmike's Avatar
Hello everyone. I have a 2003 f150 5.4l 2v. I have a lean code on bank 2 and I can't find the vacuum leak if it is a vacuum leak. Here is what I replaced so far. 1. Intake manifold w/ new gaskets and hardware.
2. All 4 o2 sensors.
3. Vacuum lines that I seen were worn.
4. New fuel filter
5. All 8 fuel injectors.
6. All 8 spark plugs and coil packs
If anyone can help me figure this out I am stumped.
Old Feb 10, 2020 | 11:20 PM
Do you have an exhaust leak on that side before the upstream O2 sensor? Have you checked the PCV elbow behind the intake for rot and cracks?
Old Feb 11, 2020 | 08:24 AM
Txmike's Avatar
no exhaust leak on bank 2 before the upstream o2 sensor. Pcv elbow if fine no cracks no rot. That's part of the hoses I replaced just in case. I did a little research to common issues to check. After I replaced the 2 downstream o2 sensors last night I cleared my codes and the only thing that came up going to work this morning was misfire on cylinder 2. My STFT1 and STFT2 is between -3 and +3%. My LTFT1 and LTFT2 is sitting at 14%. Then when I do a mission check it says something went wrong with egr and evap syatem
Old Feb 11, 2020 | 10:31 AM
What brand spark plugs and coils did you use?
Old Feb 11, 2020 | 01:28 PM
Txmike's Avatar
Motorcraft spark plugs and Motorcraft coil packs
Old Feb 11, 2020 | 02:43 PM
Can you be more specific with details?
Old Feb 11, 2020 | 10:56 PM
Txmike's Avatar
This is what pops up.
Old Feb 11, 2020 | 11:41 PM
Those should be throwing numeric codes........
Old Feb 12, 2020 | 01:27 PM
Txmike's Avatar
Glc... There lies the problem, its not throwing any numeric codes. The only code that come up is p0174 and misfire on cylinder 2. I tested it this morning.
Old Feb 12, 2020 | 01:28 PM
Txmike's Avatar
Old Mar 8, 2020 | 07:27 PM
Jeremy Cassell's Avatar
I don't know if you figured this out yet, but the egr can get carboned up and if it's not closing cause a lean condition and misfiring.
But onto the problem I had that I figured I would mention is I used to get random lean codes until one day I smelt coolant and noticed that there was leaks by the coolant crossover. Ended up being the plastic corroded around the oring and broke away the plastic and cracked the manifold just enough to cause lean codes.
Did you happen to remove the cross over and look at the plastic where the o rings seal? because I know you can remove the manifold and change gaskets without removing the crossover.
Here's a thread that is exactly what I'm talking about.
https://www.f150forum.com/f6/cracked...nifold-289173/
