Idle problems
Old Oct 31, 2019 | 05:53 PM
Kcoram1993's Avatar
Idle problems
I have a 1994 Ford F150 Flareside with the 351 Windsor in it recently changed out Plugs and plug wires ran great until for some reason once the truck it started it revs up without pressing the gas pedal acts like the throttle is stuck wide open but when i looked it didnt seem to be stuck open to me as i could still open by hand any ideas would be great and thank you in advance!
Old Oct 31, 2019 | 08:17 PM
Idle air controller is probably stuck open.
Old Oct 31, 2019 | 10:51 PM
Labnerd's Avatar
Hopefully you didn't try to clean the throttle body while it was still on the engine. If you did, you destroyed the the gasket between the lower and upper intake manifold. A high uncontrollable idle is usually the result. You cannot put any chemicals down the throttle body as they will damage the gasket.
If the Idle Air Control seems to be the issue, try cleaning it after removing it from the intake. Take a good look at the mount for it. It should have 2 ports that get clogged up and need cleaning occasionally. Again, no chemicals go down the intake so stuff it with rags if cleaning. The IAC gasket is a dry gasket and can usually be reused.
Old Oct 31, 2019 | 11:01 PM
You also may want to make sure you didn't break or knock off a vacuum hose.
