opinions needed
opinions needed
my truck's engine has seen better days (302). this upcoming summer, im planning on rebuilding the engine and i was considering adding the edelbrock power package to it. the power package includes new aluminum heads, new aluminum intake and a bigger throttle body. should i go this route, or should i just install a supercharger after the rebuild? thanks for your opinions!
In My Opinion...
I think it really depends on your budget. If you really want to get the full benefit of the supercharger then you are going to want to go with heads and all that other stuff. But if your just looking to step up the performance a bit while retaning reliability, I would just go with the package deal. I'm sure it would give your truck a healthy boost. But that is just my .02 and I have been known to be wrong a time or two.
Good luck,
Bones
Good luck,
Bones
PERFORMANCE UDATES
You will probably find the "package" will be more reliable then the supercharger. The supercharger is great, but you would have to make sure its set up for the blower, and you have to limit the amout of boost. Then there is the detonation problem.
Stay with the "package."
Mike C.
Mike C.
Originally posted by redlariet
Donate54
I had a 90 lariet 302 that was a real dog. every part I tried , the EEC-IV & sensors cancelled any gain. better check with Mike T. in computer chips section to see if a chip can be burned to correct for the new goodies.
Donate54
