1998 F150 4.6 Missing Under Acceleration
That's what I thought. We will not be driving the truck until I change out the plugs tomorrow, my grandfather doesn't have to work until Sunday I think. This time, I'm replacing them with genuine Motorcraft Plugs, and torquing them down correctly. Also, the plug wires keep coming loose. Most likely caused by loose plugs, not sealing correctly in the well. Hopefully my woes will be over soon, then maybe this truck will last me to get my license.
So, after breakfast, and some careful thinking, I started work on the plugs. Sure enough, plug 8, the one I noticed coming off more, was VERY loose. All 8 plugs were switched out with Motorcraft ones, and, not to my surprise, the truck runs like it's brand new from the factory. Thank you all for the help, now I have to wait for my hands to heal.
OK, will check when I get the chance. Number 7 is the only one that has been having problems, otherwise the truck runs just fine. I really need to get this fixed soon, it needs to be smogged by the end of the month.
Ok, when my grandpa got home I took off the wire, which was loose, took a microfiber cloth wrapped around a small screwdriver and wiped it out. Sure enough, all that was in there was a little bit of black gunk. I looked in the wire and everything seemed straight, so I put some grease in the boot and put it back on, making sure it was snug. So far, everything seems to be running good, I'll come back with any updates if anything happens again.
I cleaned out the wires, put some dielectric grease, and it runs great. No more wires popping off after a mile or two. Put about 30 miles on it this morning, and nothing happened. Then I took it to get it smogged, and it passed. Thanks to everyone who helped me out!
