1997 4.6 wont start
Old Nov 27, 2017 | 02:24 PM
officernine's Avatar
1997 4.6 wont start
I was in a drivetru the other day and shifted my truck into park. then once I shifted back to drive it just died and wont start back up. I have replaced the battery, multiple relays and fuses, and the fuel filter. The engine is getting fuel and the fuel shutoff switch has not been triggered. Is there anything else I am forgetting? It turns over and starts sometimes but just dies instently.
Old Nov 27, 2017 | 05:33 PM
Check the fuel pressure with a gauge, it has to be at least 28 psi to start. Gauges can be borrowed or rented from most parts stores. Use an inductive tester on a plug wire and see if it's getting spark.
Lisle 19380 Spark Tester
Amazon Amazon
Old Nov 27, 2017 | 07:03 PM
trying88's Avatar
I have almost same problem 98 2wheel v6 f150 . direct wired fuel pump have fuel to rail lots of pressure and great spark but no fuel getting to sparks ??? any ideas
Old Nov 28, 2017 | 04:05 PM
Ok so it has pressure and they are getting a spark and the truck is starting up but it wont stay on.
Old Nov 28, 2017 | 05:22 PM
Does it have ENOUGH pressure? Will it keep running if you give it a little gas? Any OBD2 codes?
