2007 Harley Davidson F150 Coolant Temp Sensor Location?
Hello all, can anybody tell me where the coolant temperature sensor is located on a 2007 Harley Davidson F150 with a 5.4 V8? I was told it was located in the same location as the following video:
but it is not. Thanks
The video is for a 2 valve engine, You have a 3 valve.
You have both a cylinder head temp sensor and a coolant temp sensor. One is for the gauge and the other is for the ECM.
https://www.tascaparts.com/oem-parts...sor-9l8z6g004c
https://www.tascaparts.com/oem-parts...r-4l3z12a648ab
He only has one sensor, the CHT sensor. There is no second coolant temp sensor, that's why he can't find it.
The gauge in the instrument cluster is driven by data from the PCM from the CHT.
Excerpt from maintenance manual for his engine.
Temperature Gauge
The PCM receives the engine coolant temperature status through hardwired circuitry to the cylinder head temperature (CHT) sensor. The instrument cluster receives the engine coolant temperature data from the PCM over the communication network. The instrument cluster monitors the engine coolant temperature data received from the PCM and provides the temperature gauge indication with a corresponding movement of the pointer. If the instrument cluster receives no signal the temperature gauge defaults to the COLD position.
Interesting. The truck started driving strange (as if air fuel mixture was off/fluctuating) about a week ago. So I took it to autozone and they scanned it and came up with these two codes: P1289 and P0119. The P1289 was taken care of with the replacement of the coolant head temp sensor. Any idea as to what the P0119 code is for? The truck is still not running right.
Then why does Tasca and Rock Auto list both sensors?
EDIT: Okay, I dug into it. The 1998 model year was the last one that Ford used an ECT sensor to monitor coolant temps on the 5.4L truck engines.
P0119 is for a ECT sensor issue.
P1289 and P0119
I'd be looking at the wiring to and from the CHT sensor next, assuming that the replacement CHT is good. I've seen a number of cases where the wire was broken inside the insulation. If the wiring is good, then it's likely an internal problem to the PCM. That said, I would not jump into condemning the PCM without have an experienced technician make that diagnosis based on a hands-on evaluation.
