2010 4.6 very loud knock
Old Oct 21, 2017 | 09:39 PM
critter011993's Avatar
Exclamation 2010 4.6 very loud knock
i was driving down the road the other day and herd a tick very faint so i parked the truck at home starting it the next morning it had a very very loud knock i took vale covers off expecting to find a bent rod or broken arm yes its a very loud knock but everything seems great and in place timing, rods, arm, elct,.... im not sure what els to look for it runs normal just that loud knock my check engine light also came on when this happened but all i got was lean codes im stumped
Old Oct 21, 2017 | 10:27 PM
2 valve or 3 valve? Please post the exact codes by P-number.
Old Oct 21, 2017 | 11:58 PM
JackandJanet's Avatar
And, critter - I deleted the post about this problem you made in another thread. Please don't create multiple posts or threads about a problem. They lead to confusing responses that can waste your time and cost you extra money.
- Jack
Old Oct 22, 2017 | 10:50 AM
3 valve codes were P0174 P0174 P P0171 P0130
Old Oct 22, 2017 | 10:51 AM
- Jack
okay sorry about that could not figure out how to start a new thread haha
Old Oct 22, 2017 | 11:34 AM
Check those codes again please - you have P0174 twice and a P nothing.
Old Oct 22, 2017 | 11:57 AM
code 1 [P0174-P] code 2 [P0174] code 3 [P0171] code 4 [P0130]
Old Oct 22, 2017 | 12:07 PM
Ok, that's a stored P0174 plus a pending P0174.
You are lean both banks and have a possible bad O2 sensor in the front on the passenger side.
Hopefully, the knocking is just a bad phaser. Lean is usually a vacuum leak. How many miles on the engine?
Old Oct 22, 2017 | 12:12 PM
300k i thought it might be the phaser but its so loud compared to what iv herd and coming from the rear not front like i said it runs great has full power the tuck is loud and you can here this knock over the truck literally sounds like someone hammering on metal
Old Oct 22, 2017 | 12:25 PM
300k! Time for a teardown and rebuild.
