Fuel pumps right back through return line
#31
#32
just wonderin, because I bought a cheap pump,, do you guys think the pump i bought is bad?
#33
Spraying starting fluid (ether) right in the Throttle Body is replacing the gasoline that should be coming from the injectors. If you do not get at least a pop or sputter you aren't getting any or enough spark. You should re-verify you do have spark, check the fuses first sometimes it's the simple things. Verify voltage at the coil with a voltmeter, etc.
That said if you got no sputter I can't say weather it's a bad pump, that pressure gauge will verify good or bad pump
#35
You didn't say weather or not it popped or sputtered? I used that method on a truck that had quit running, we thought the pump went bad. Sure enough, with a spray of ether right in the TBI it would start and run for a second or two.
So today I got the pressure test kit and wouldnt you know it, I cant get that to work either. I put it on the rail, pinched the return line, and it shows nothing. Nothing comes out of the bleeder either. When I unhook it I take another bath in fuel spray, yet again.
Im beginning to think this thing is cursed.
#36
#37
There was another poster who borrowed two or three pressure gauges from his parts store because the first or second didn't work. So it isn't impossible to believe that if they loaned you a used tool that the last guy f'd it up. Patman suggested a flow test, you said you had the box off for easier access right? If you could disconnect the supply line to the engine and connect some extra fuel line to the pump output into a 5 gallon gas can and time how long it takes to fill it when you power the pump up.
#38
#39
#40
ok great, I just put 10 gallons in it thankfully, so I can time how long it takes to fill a 5 gallon jug and post it tomorrow. Thanks again.
#41
Well, unfortunately its been raining on and off so I havent had the chance to flow test it yet.
I did get a new regulator, and it made no difference. The same thing happens when I turn the pump on, you can hear all of the fuel it pumps whoosh right through the rail, past the regulator, and right back through the return line.
I called Ford and the guy told me to stop getting regulators from Autozone, as they may have a bad batch of them. So I called Napa and they have a different brand, so gonna try that tomorrow when they get it in.
I took back the faulty pressure test kit to Autozone and they said they didnt have another one, so looks like Im out of luck on that front for now. It may neccessitate a trip to the bar to ask around, and for my mental health.
#42
#44
thats right, I still have the OBD computer tester, and have been doing the Key On Engine Off test to run the fuel pump, and listening to it just run back through the return line. This is fuel pressure regulator #4, counting the original one. Something has to be wrong with the mounting points of it. I will make a video of it tomorrow for you guys, it may be of some help.
