Stumped on this 4.6 ford motor in lincoln town car stretch limo
Old Sep 5, 2016 | 01:47 AM
Travis Ipsen's Avatar
So it has a knock coming from driver side top of motor. Which leads me to believe that somethings loose but what I can't seem to find out is how to adjust the lash oil pump is good and have pressure so got any ideas thanks
Old Sep 5, 2016 | 09:35 AM
Valve lash? That's not adjustable, it has hydraulic cam followers.
Old Sep 5, 2016 | 12:03 PM
Roadie's Avatar
Make sure it isn't an exhaust leak first. Then if you remove the valve cover, you might see what the problem is.
Old Sep 9, 2016 | 09:17 PM
DYNOTECH's Avatar
First remove the serpentine belt to make sure its not a FEAD component or pully bearing. Then check sparkplugs for a loose plug. Then remove the cam cover and look for a collapsed lash adjuster, worn cam lobe, damaged roller finger follower. If all this proves nothing wrong then the intake manifold may have to come off. Do you have a missfire and any codes? have you used a stethoscope you try and get and exact location of the noise?
