need advice on mainteance,19,000 miles on 2001 screw
Old Sep 17, 2001 | 05:16 PM
CRAZY-SCREW's Avatar
Question need advice on mainteance,19,000 miles on 2001 screw
first time posting some-thing in here,my question is what should i do now that i have 19,000 on 2001 screw. i have the 4.6 and up to this point the only mainteance i've done is change the oil every 3,000 miles, motor craft filter and castrol 5-30w.
the last few week's i feel like the engines hesitates to pick up rpm's i'am planning to install 40 series delta flow f/m and k@n filter in the next couple of week's for extra h/p but besides that can any one tell me what kind of mainteance i could do to keep the truck in good conditon's
thank's in advance!
Old Sep 17, 2001 | 06:31 PM
MitchF150's Avatar
Wink
No mention of an air filter change or fuel filter change. Those could be contributing to the hesitation problem.
Old Sep 17, 2001 | 07:25 PM
S-76's Avatar
Thumbs up
Hey there!
I currently have the Airaid FIPK w/ K&N Filter. I just recently noticed the same thing with my 5.4
Here's what I did.
Disconnected Neg. Battery terminal to reset the ECU.
Removed my K&N and knocked out the loose dirt. Note I didn't recharge it yet. Removed my MAF and GENTLY cleaned the element wire with a Q-tip and Windex. Filled her up with some good gas, and drove it like I stole it for 200 miles. LOTS of going through the gears at WOT. Changed the oil.
She is running like new.
Old Sep 17, 2001 | 07:30 PM
BJays Red 150's Avatar
Sounds like it's time for that air filter, 20k miles on the factory one is a little much, obviously, pending on where you live...
After that, or during, before, whatever, try a fuel additive. Something like Castrol's or whatever, a fuel system cleaner (STP I use) that will also help with the hesitation.
Old Sep 18, 2001 | 11:40 PM
hmustang's Avatar
I say do your oil changes the way you been and do the air about every 20,000 and change your fuel filter by 50,000 if not before.
