New here near grants pass oregon
Old May 4, 2016 | 04:13 PM
railroaddaddy42's Avatar
Help Blown spark plug 2006 F150 4.6l with Romeo heads. Do I need to use time sert 5553.
Old May 4, 2016 | 04:16 PM
I have read up on heli coils and they don't seem like a good fix to me. I called ford shop and they want to use a heli coil.Full insert seems the way to go. Any advice THANKS
Old May 4, 2016 | 04:19 PM
Helicoils have a high failure rate. Timeserts are permanent.
I'm going to move your thread where it will get more hits.
Old May 4, 2016 | 04:24 PM
Thank you still learning how to use the forum
Old May 4, 2016 | 05:20 PM
Not a problem, good to have you here.
Old May 4, 2016 | 06:51 PM
The only 2 inserts that last are Timesert and Lock N Stitch. The Ford dealer SHOULD be using Lock N Stitch, not Helicoil - that's the only "factory approved" repair.
Old May 4, 2016 | 07:04 PM
That's funny because I called them today hoping that the repair would be cheaper than the tool and the teck told me they would use a heelicoil. I could not believe he said helicoil and I asked him twice. Is the lock n stitch product any cheaper than timesert THANKS Bob
Old May 4, 2016 | 08:34 PM
Are you prepared to do the work yourself? We have a couple members who have the Timesert kit for rent.
I'm surprised a 2006 had a blowout - those have the improved 8 thread heads. Last person who changed the plugs must not have torqued them enough - we recommend 28 ft/lb. Factory spec is way too low.
Old May 4, 2016 | 09:23 PM
Yes got ahold of Projectshop89 his is not available till next week.Do you know another member that might rent it. THANKS Bob
Old May 5, 2016 | 10:00 AM
You can try Galaxy, but he hasn't been too responsive lately.
Old May 5, 2016 | 11:52 AM
ok thanks glc Ill try that
