Acts like its out of gas?
Old Dec 30, 2015 | 07:15 PM
2001SuperCrew4x's Avatar
I hope so too. What a pain to change out though.
Old Jun 25, 2020 | 09:10 AM
Jeff Surmatis's Avatar
Jeff
Originally Posted by 2001SuperCrew4x
2001 Supercrew wth 5.4. On Thursday leaving work it act acted like it was out of gas truck finally died would not restart but would turn over. I know it was not out of gas but I added 5 gallons from work truck started right up and drove 20 miles parked it for the night started up started up just fine in the morning drove another 20 miles parking for the day. Drove to work this morning parked it in the shop went to leave act like its out of gas again I know it's full of gas because I filled it up yesterday. It will start up and run for a bit and then die. Does it sound like a fuel pump issue or maybe some bad gas? I bought a fuel filter so when I get to work tomorrow I will try that as the truck is still there. Any help would be greatly appreciated.
Im dealdealing with the exact same thithing. Through trial and error Ive boiled it down to either the fuel pump or the fuel pump pressure actuator located under the spare tire. Note: I'm a carpenter not a full time mechanic.
Old Jun 25, 2020 | 10:49 AM
What year?
Old Jun 25, 2020 | 03:36 PM
Roadie's Avatar
It should be easy to check the fuel pressure if your truck is a 97 to 03 at the shrader valve on the fuel rail.
Old Jun 25, 2020 | 04:59 PM
I'm guessing it's a 2004+ because he talks about a module by the spare tire. That would be the FPDM which needs to be removed and checked for corrosion.
