1995 351W cranks but wont start
Old 09-28-2015, 08:46 AM
Michael Roberts's Avatar
Okay I am Very confused.
I have a 1995 Ford with a EFI 351W. It wont start.
It will Crank over but no start
I have checked the following:
Fuel Pressure on the rail about 40PSI while cranking.
I have spark. Tested with spark tester on several plugs. Checked timing by removing plug 1 set at 10 deg btdc rotor is set on plug one.
I tried spraying starter fluid in still no start. I have another running truck with same engine and I have swapped the efi module and distributor from that engine and same results.
I am looking for advice and direction to resolve
Quick Reply: 1995 351W cranks but wont start
