Engine knock
Old Apr 5, 2015 | 09:34 PM
DYNOTECH's Avatar
Originally Posted by Project Ford
Just to try to clear things up, this is a dull knock, NOT a ping, this is a sound similar to knocking your Hand on wood not the same but that kind of dull tone only happens once and on the tranny side I can move the drive shaft up and down just a little bit is this normal?
Anything is possible..If you suspect the U joint then change it not expensive. One knock only one time on startup or rather on acceleration from a stop. I would lean toward the drivetrain at this point. Others here have more experience than I do with tuning issues so if they say they have had that problem I would believe what they are saying and change things up to see if it solves your problem. JMO.
Old Apr 5, 2015 | 09:38 PM
DYNOTECH's Avatar
Originally Posted by Markes12344
Little bit of a thread jack. You mention the old 302s may experience a rod knock, well my 302 has recently been a victim of this. 40k km unto the re-maned long block. The noise becomes more prominent when oils warm. 100% now it's rod, every stroke, only the one.
Although it may not be a problem is there anything that can be done about it. Like a pull and clean of the lifter?
Well sometimes I give more information than is necessary and make things more confusing than it has to be...lol.
The noise issues I was referring to on both the 5.4 an 5.0 was piston related not rod and was not a durability concern.
Old Apr 5, 2015 | 10:19 PM
RevBiker's Avatar
power brake in drive w/ hood open to see if engine is lifting up. Broken motor mount?? Sway bar links ok? u-jts shouldn't have any movement in them, but shaft may move a little in trans up & Down.
Old Apr 7, 2015 | 12:51 AM
rocketman9830's Avatar
5.4ford engine timing marks
2004 5.4 engine is a interference engine , it was posted as non interfaces engine Which is wrong & misleading to those who want the right information. If turn the motor over it will cause valve damage if timing marks. Are incorrect posistion.
