01 F150 4.6 engine swap with 08.CVPI. Help Please.
Old Jan 28, 2015 | 04:24 PM
jozepy's Avatar
Gaskets What a cluster !!
So I do not have the vin on this 2008 crown vic 4.6l engine. Without it seems that I cant find the right gasket set for it!!!! Now I understand they made a few variations but you would think they have sets with all the possible gaskets ?
Old Jan 28, 2015 | 04:29 PM
jozepy's Avatar
Originally Posted by jethat
Te CV exhaust system is totally incompatible. Might be able to use the mufflers if you exited out the sides. cant use the x drive line gets in the way. The spare tire gets in the way of doing true duals all the way out the back on both sides. Generally they exit them out the passenger side on these trucks. You can fab up what every works. Your truck!
Ok I am going make life easy and just put it back stock.
Thank you for the help.
