is there a way to test coil packs
Old Sep 2, 2001 | 12:20 PM
L in Detroit's Avatar
i have a rough idle and no power when accelerating and had all the packs out and did a physical check , is there a way to test the 5.4 coil packs, using the normal test equipment..
Old Sep 2, 2001 | 07:00 PM
Mach1's Avatar
Use a ohm meter and check the circuits to ground, both primary and secondary sides and then there should be a resistance vaalue check...
I dont have the specs in front of me right now, or I could tell you...
You should not have any shorts to ground or that coil will be bad..
Old Sep 2, 2001 | 10:15 PM
max mitchell's Avatar
L in Detroit-
4-10 Kilohms resistance between the 2 coil pins.
