4.6L Oil Filter
Old Aug 30, 2001 | 08:22 AM
buckslayer's Avatar
4.6L Oil Filter
I'm looking at two different used SC, 4X4's with the 4.6L engine. On the '98, the oil filter is located in the front left corner of the engine compartment, tucked up behind the bumper. On the '00, the oil filter is on the engine, way down behind a lot of hoses and componentry. My question - did Ford change something, or does the '98 had some remote oil filter kit? That '00 sure looks like a tough filter to get at for changing oil. How tough is it, guys? Thanks
Old Aug 30, 2001 | 08:56 AM
Rob_NC's Avatar
Don't know about the changes but I will say that the drip pan under the filter on the newer engines does exactly what I called it. It drips oil all over my garage floor. Poor design if you ask me. Serviceability stinks.
R
Old Aug 30, 2001 | 09:22 AM
T Ellenberger's Avatar
Some of the 4WD models came with the remote oil filter. From what I have read here the @WD models had the filter on the engine. My 97 2WD has the filter on the engine.
Old Aug 30, 2001 | 01:47 PM
t_daughrity's Avatar
Can't speak for the '00 but my '97 4.6L 4x4 is a reall pain in the *** to change on the motor. I only wish mine was remote mounted where I could actually get a hand on it. Oh yeah, my '97 has a drip pan on it too, they are called the transfer case, front crossmember, etc. What a mess. If you don't get up in there with a rag or something after an oil change you get this nice burning oil smell for about 3 weeks afterward too........
Old Aug 30, 2001 | 02:43 PM
buckslayer's Avatar
Anyone know where to get a remote filter relocation kit? I've looked this engine over well, and it appears that changing the oil won't be the only thing that's tougher to do than it should be -- am I right guys?
Old Aug 30, 2001 | 02:49 PM
The plugs and wires are not exactly a joy either.
Old Aug 30, 2001 | 10:35 PM
Wendell's Avatar
My 97 4x4 has the remoted filter. Real easy to change. I didn't know this was an option. Now I'm wondering if it includes any type of oil cooler??
Old Aug 31, 2001 | 09:06 AM
Tiger's Avatar
JC Whitney has a Permacool remote filter kit for under $50. Was thinking about doing one myself. I've changed my oil 4 times now and although it really isn't as difficult as it looks, it is very messy. I generally waste a bunch of paper towel cleaning the drip pan. It is also very important to have your wheels either straight or turned one direction. Can't remember which way they should be turned though. Last time I changed it I had the wheels the wrong way and the filter unscrewed ok, and dumped its load. but I couldn't get it out from behind the steering crossmembers. Now picture an oil filter pouring out, you can't remove it because the wheels are turned the wrong way and anybody ever tried to turn the fron wheels, sitting still without power steering after wiping the oil off a hand. ##$@%%####!@@!!!
Old Sep 2, 2001 | 02:00 AM
Jazzpro's Avatar
Post
The original Ford parts to add the factory remote oil filter are as follows
frame bracket 1GT6538
remote oil filter mount F75E6884GA
hose assy c/w seals F8TZ6716AA
engine block adapter F756B894DB
lower Rad Hose F75A8B273TB
O ring Kit
Bolt set
These are the complete set of part numbers from the original factory remote oil filter which I removed when I installed the factory oil cooler from a wrecked F250LD 5.4L on my 4.6L F150
Jazzpro
Old Sep 2, 2001 | 04:12 PM
OffRoadLariat's Avatar
Exclamation Summit
Summit has one of the relocation kits too. I tried the one that Perma-Cool makes.... it sucks!!!!!!!! You have to put the clamps on real pain!!!!!!!! Summit Racing has one TD Relocation kit & hoses are maded up no SS clamps to come loose like perma cools. I have this one on now for 8 months no leaks at all. Real nice & easy to get filter off. Plus I put on a Fumoto Drain vavle too. ..Lariat#1 has this one too, look at his signature.
OffRoadLariat
