Rattling Noise on Cold Start
Old Aug 29, 2001 | 05:43 PM
Mattro2003's Avatar
Lightbulb Rattling Noise on Cold Start
I have a 1999 Ford F-150 with a 4.6L Triton V8. When cranking my truck on a cold start the motor revs to 2k rpms and makes a rattling noise which sounds like the crankshaft is starving for oil. The dealership tells me that this noise is normal. I do not believe that this problem is good for my engine. If you have any information regarding my problem please reply and let me know. I can't seem to get a straight answer from anyone regarding this problem.
Old Aug 29, 2001 | 06:00 PM
Dennis's Avatar
If you're running the right oil and the right filter as spec'd in your owner's manual, the noise is not normal unless you haven't started your engine for a few days and/or you have a ton of miles on your engine. If you start it daily, you should not hear any rattling noises from inside the engine.
Old Aug 29, 2001 | 08:26 PM
junkman's Avatar
Post rattling noise
Mattro2k3,
Is your vehicle parked outside...i.e. suceptible to moisture. I had a similar problem with moisture collecting in the belt housings and causing a "rattling" noise for approx 30 seconds until the moisture was released. The remainder of the starts in a day are "noise" free.... My .02....I don't have the problem when isolated from dew, rain etc.. Anything similar???
99 4.6l
JM
