2009 f150 5.4 o2 sensor
Old Jul 15, 2013 | 01:50 PM
williabd's Avatar
Hey guy's,
I have a 2009 Ford f150 5.4. This past week my check engine light came on and the code was p0130. It seems to be a 02 sensor bank 1, sensor 1. After doing some research, it appears the 02b1s1 is located on the passengers side near the exhaust manifolds, correct? How would I go about changing the o2 sensor?
Now after i unplugged the Check engine light scanner, my check engine light disappeared. From past experiences, the check engine light usually stays on.
Thanks!
Old Jul 15, 2013 | 01:55 PM
http://www.obd-codes.com/p0130
Bank 1 is passenger side and sensor 1 is the one closest to the engine.
O2 sensors should be covered under the Federally mandated 8 year/80k mile emissions warranty. Discuss this with your dealer.
Old Jul 15, 2013 | 02:03 PM
williabd's Avatar
Unfortunately I have passed the 80,000 mile mark already. What would be the best route on changing the o2 sensor so I dont have to pay an arm and a leg to have someone fix it?
Old Jul 15, 2013 | 03:35 PM
Did you read my link thoroughly? Simply changing the sensor may not fix it, you should follow some troubleshooting steps.
Use your scanner and clear the codes, see if they come back. If they don't, it was an anomaly and I wouldn't worry about it.
If you are approaching 100k, you need to change the spark plugs.
