Engine ticking sound.
Shot in the dark. Engine starting making a ticking sound. I am hold my phone near where the exhaust manifold meet the exhaust pipe. Any ideas....I am hoping exhaust leak.
2001 F150 supercrew 4x4 5.4
Your video is not working for me but yes these trucks have poor quality exhaust manifold bolts that rust and break off. Have a look to see if you are missing a bolt head or two and if you are that is most likely your problem.
I see...I can't seem to figure out to make it a public clip....and it will of duplicate the download?
Now you should retorque all your plugs to 28 ft/lb. Loosening and blowout is a common issue with these engines. When they blow out, they will take the threads in the head with them and you will need to install Timesert inserts.
Factory recommendation is 14 ft/lb, and that's the main reason for the blowouts.
http://blownoutsparkplug.com/
Read FAQ's #51 and #52.
