Eletric fan conversion?
Old Jun 19, 2013 | 09:20 PM
MeanGene's Avatar
Here is what the FAL 270 looks like installed.
I mounted the controller on the firewall behind the battery.
Old Jun 19, 2013 | 09:27 PM
beechkid's Avatar
25 Year Member
Originally Posted by grizzstang
Ford does not make a "kit". You would need to buy the efans from Ford (or find a set in the wreckers) from a 2009 F150 or newer. Then you would need to do some triming on them to get them to fit. You would still need to get an aftermarket fan controller to run them. The PCM would handle that job on the newer trucks.
just an FYI- oem replacement units are available at autopart stores.....
MeanGene's Avatar
Just ran across a Brand new Troyer Fan kit here in the For Sale Section.
https://www.f150online.com/forums/pa...brand-new.html
Old Jun 19, 2013 | 09:42 PM
fx4jody's Avatar
Originally Posted by The King
Hey Grizzstang, I have troyer fans also and a couple of years ago got rid of the troyer controllers and bought a FAL controller. I wired it so both fans go on at the same time. FAL controllers have a soft start and only run 60% at start up and increase to 100% if the temp increases 10 degrees over your initial setting. Mine have never gone over 60% and I live in Az. Having both fans run at same time cools the whole radiator, not just half of it. I love it. I also figured out a way to keep the fans from running at highway speeds with a/c on. If you want to know how I did it, let me know. It's cheap and easy to do.
Yea let us know how you did that
Old Jun 20, 2013 | 10:24 AM
grizzstang's Avatar
So far, knock on wood, I have been happy with my Dakota Digital fan controller but I would like to hear more. I thought about wiring mine so both the fans come on at the same time too but in the end I didn't because my controller does not have a soft start. I bought my controller and relay because it handles 70 amps. Probably overkill but I was not impressed when I melted the Troyer controllers.
Old Jun 20, 2013 | 10:30 AM
grizzstang's Avatar
I really like having some sort of shroud around the electric fans. In my mind it can only make them more efficient. The Troyers do not have this.
Old Jun 20, 2013 | 06:26 PM
The King's Avatar
e-fans off at highway speeds
Ok, hers what I did: I went to autozone and bought a cheapo fan controller. It was about 17.99 and I stuck the probe in the middle of the a/c condenser between the fans and set the new controller at a temp a bit lower than when the high pressure switch kicks the a/c compressor off. I think was about 160 degrees with a thermal gun. Make sure the probe is in between the fans because if it is the direct path of a fan it will cool before the condenser is cool enough. There's only 2 wires on the cheapie controller, so hook one to a positive ignition source and the other to your a/c input on the FAL controller. You will no longer need the wire from the a/c compressor. I've running this setup after a little tweaking on adjustments for about 2 months and it works perfect. My a/c stays cold in town with the fans going on and off and they have not come on once on the highway. Also I put a piece of insulation between the radiator and the probe because when I was stopped or in traffic the new probe picked up the heat from the radiator and kick on the fans, but the insulation fixed the problem. I bought a cheapie controller because I wasn't sure it would work, but now that I know I may get a better one.
Old Jun 21, 2013 | 07:50 PM
LincolnMarkLT20's Avatar
If I buy a 2010 Ford F150 fan I can run it with a fan controller for my 06?
