missfire
Old Jun 7, 2013 | 09:24 PM
FabianB's Avatar
missfire
Ok I have a 99 f150 with the 4.6 v8.I have a hesitation / missfire on my truck. I know something is up bc I can feel it jerking when I accelerate and when Im in a high gear its sluggish. No codes or check engine. Its been like this for about 2-3 weeks. I have changed the plugs about 15k ago and fuel filter as well as the fuel pump. Don't think its the invjectors or a vacuum leak or clog cats. I have not replaced the coils ever. And the wires for about 3+years. I'm running out of ideas please help.
FabianB's Avatar
Also I have 186.000 on the motor and trans.
Old Jun 8, 2013 | 12:47 AM
Toyz's Avatar
186k on the coils... I would say it's time for new ones. Sounds like a low grade misfire to me. Good place to start anyway and to know you have new ones.
Old Jun 8, 2013 | 11:42 AM
ParnAZ's Avatar
Ya at 186k it might be time to change a pack. I just had to change my coil pack at 165k because I up and lost #4 completely. That high gear issue is usually when you notice the misfire like 45 mph in overdrive under light throttle
Old Jun 8, 2013 | 08:21 PM
Roadie's Avatar
Are you sure it's not the infamous mechanical lockup of the torque converter slipping? That shows up typically at low speed under light acceleration.
