MAF VREF: 0v @ ECU?
Old Jun 2, 2013 | 10:12 PM
jbrew's Avatar
Old Jun 2, 2013 | 10:14 PM
jbrew's Avatar
Yours should look like this, -
Old Jun 3, 2013 | 02:06 AM
Klitch's Avatar
You mean to tell me I've been chasing 5v for no reason? I'm pretty sure Troyer was the one that told me I was missing 5v reference at the MAF.
Thanks JBrew.
Old Jun 3, 2013 | 04:52 AM
jbrew's Avatar
Thanks JBrew.
No problem. I guess I couldn't figure out what you needed.
What Mike probably meant is @ WOT you should have 5v(or 4.75v to be exact) on the MAF return/ground and it's not there. That shouldn't matter IMO, but I'm not a tuner either. Typically it goes from 0("idle")-4.75V("wot") on the return/ground. I believe that can only happen on a dyno tho, - the VSS info/data is used to calculate in relation to signal as far as I know. So unless you have the rear tires off the ground Trans in "D" and peg the throttle WFO, your not going to see certain output numbers go thru their ranges. I can't recall which ones won't read, dangit.
They say to keep in mind,- the MAF is only one part of a group of sensors that are used to calculate fuel tables/trims, or AF's. Although that is true, it's sort of misleading. - Since all it would take is one screwed sensor to thro things out of wack. On that vehicle, there isn't a whole lot of MAF DTC's that give you direction.
Anyway, -If you need more help with how to test that, let me know where you get stuck. Hopefully, I can pull you out
BTW- The typical MafSigVolts are 0.60 @ idle, 1.10 @ 20mph, 1.70 @ 40mph, 2.10 @ 70mph.
The MAF return ground should vary between 0-4.75v depending upon where your at with the above.
Old Jun 3, 2013 | 01:44 PM
Klitch's Avatar
Cold start, 1.06v - 1.20v @ idle
Warm hovered more around 1.2v - 1.4v
Is that table for NA motors or does it apply to the sc models too?
Old Jun 3, 2013 | 02:27 PM
jbrew's Avatar
Not sure what your referring to now? Where are you reading what?
Old Jun 5, 2013 | 11:52 PM
Klitch's Avatar
This is what I was responding to
