flushing eng before oil change
Old May 7, 2013 | 08:22 PM
FF301's Avatar
ok- high milage eng with a tap, found the "intake manifold runner control" linkage had come apart on one bank not realy sure what it does. temp fix in place till i can get propper clip from ford.
but oil light comes on at idle so going to change sensor and install gauge to check things out (sensor only $16 so just going to change out)
but should i flush it with sea foam or something else to clean passages, not sure how it would effect tapping don't want to make it worse.......
oh ya- 2002 windstar 3.8l eng.
sorry - i'm posting on here because it has the most viewers and eng guys
Old May 8, 2013 | 02:38 AM
No, do NOT try to flush it out. If you know for a fact that it's all sludged up, use AutoRX exactly as directed on their website.
Old May 8, 2013 | 01:34 PM
FF301's Avatar
ok thanks, i'll know more when i have time to pull oil pressure sensor and get a look inside.
oil on dip stick seams good, and no biuld up on filler cap.
will look at rx site.
