Power steering pump info ASAP
I have my engine partways apart in an attempt to replace my timing chains, phasers, etc folowing this guide http://www.f150forum.com/f4/phaser-c...es-too-158757/
The problem is I cant get the power steering pump bolts out. In fact I cant even figure out how to get them out let alone the physical limitations. The bolts are so tight I cant break them loose with an open ended wrench (too close to frame etc to use socket) I cant figure out how though once loose they even have room to back out. HELP!!!!!!!!!!!!!
BTW I should mention I read the above post in its entirety and I never remember reading anything about the stupid power steering pump being an issue.
