2000 ford excursion 4x4 engine 5.4
i change the spark plugs , oil change , gas filter , oil filter and while i be drivin it something is not right when it hits 30 steady or 65 it feels like shaking until i press the gas pedal and it goes away i wanna know wast wrong
You should have used grease, pull them off, inspect for damage, and reinstall them with a small amount of grease in the boots. If that doesn't help, I'd replace them all because trying to find which one or ones are weak is a pain.
http://www.ebay.com/itm/FORD-E150-F150-VISTEON-IGNITION-COILS-DG508-ALL-8-BRAND-NEW-/181091202637?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a29e0764d&vxp=mtr
Those are OEM, and less than half the price of the dealer or parts store.
Motorcrafts are the best plugs, aftermarket plugs and/or coils will not increase your torque one bit.
If those are the original boots, the heat has probably made them subject to cracks. I would replace all the boots. And use dielectric grease.
