no antiseize on plugs?
Since New ,25-35 k amsoil 0w20 oil changes with eao11 filters,amsoil pi every 5 k miles ,never an issue with plugs ,copper anti-seize,torqued to 29 ft lbs just did 5th set ,treated 5.4 to New cops for the first time at 500 k,zero engine issues,OEM trans imploded tc @68 k,2004 e250 5.4,great engine!
You're less than half way there. Ever Google "Million Mile Van"? I believe the engine went to over 1,150,000 before it went and I think the trans went to almost the same, or close. Heads and pan never were off and trans pan was NEVER off!!! '98 E-250 5.4L
Your '04 is 2V right? That is a great engine, more old school, not the 3V and no cam phasers.
Update: Just checked and it went 1,299,986 before the engine died and 1,211,950 before the trans had to be overhauled. He has said that he had trans. flushes done every 50K mi I believe but that the pan had never been off it! It was a '97, not '98.
Good point,I'm **** on the anti seize,at least they were consistently inaccurate,differential serviced at 118 then 200,300,400,and now 500.trans was filtered and flushed at 118 with optional v-10 trans aux cooler in line,then at diff intervals.obviously with amsoil fluids.I'm shocked it still runs as well.as running strong.troyer tunes since 1800 miles.I run the snot out of this van
The thing that concerns me with antiseize is the possibility it will help the plugs loosen by themselves. However, at 29 ft/lb torque you are minimizing that possibility. Motorcraft plugs don't really need antiseize because the threads are nickel plated to minimize the dissimilar metal issue.
The 2V plugs don't stick - and being an 04 you probably have 8 thread heads, which also minimizes blowouts.
I always use Anti Seize and never had an issue. Just make sure they are torqued correctly!
Wayne
Wayne
___________________________________________
Openclass... ? Yea, I think I've heard of yuh..
That's a good Torque #. The only thing I might worry about is breaking the plugs seal. Have you seen the old plugs before new? The ceramics get carboned up when they leak. Reason I ask, when you incorporate Anti Seize, your suppose to reduce torque by around 30%. I'm not sure how far you can push the plugs before you'll compromise that seal. (?)Anyway, - Congrats
That's not something you should always do for specific reasons. The 4 thread Triton heads are one of these exceptions.
Further details at www.blownoutsparkplug.com, FAQ's # 51 and 52.
Wayne
No offense, but I think I'll listen to a Ford master tech who has turned fixing blowouts into a very good side business. Not doubting your competence or expertise, but these guys are specialists.
http://www.lightningrodder.com/forum...ght=anti+sieze
Wayne
Yeah, he's not a Tech and probably hasn't been. That's alright. Ford Tech's don't use a anti-seize procedure with plugs. Neither does the manufacturer. It may have been different with the three valves; I haven't talked with a Tech about those in particular. But generally, they use a formula for torque if the part comes with it pre-applied. Pre-coats are common - Loctite (under the Ford Part#) is pre-applied often by the bolt supplier. Anti-Seize is pre-applied by Bosch, not sure about Motorcraft on some O2 sensors. The correct Dielectric is pre-applied in some part connectors. This usually isn't done by service unless it's TSB'ed.
The plug manufacturers like to see 12-15' lbs, but the yield is much higher. I think it's around 35- 40' lbs (just a guess). The higher you go, the more you stress the spark plugs integrity. The seal and porcelain. To use Anti-seize on a four or five thread plug chamber that uses a tapered seal vs compression can have some adverse effects for sure. One, there is a lot of plug thread reveal and that anti-seize will be pumped out by the exhaust stroke coating the O2 sensors. It may get burned off eventually, but most likely,- not without a hick-up or two. At 29' lbs with anti-seize in a 4 thread, your pushing yield and stressing the plugs. Spark plugs do fracture in a way that's hard to detect. Add in 30% and your close to 38' lbs. It's a gamble installing them with that procedure. No, they probably won't blow out, but there's other effects to be considered that should be. Specially w/boost. It's different with taller thread chambers.
