DTC Codes and ticking weird noise HELP
My engine 04 5.4 88xxx miles on it has on the passenger side a ticking clunking noise when warming up and at a idel. Today when i got done at my river property trail riding my gryphon showed me 4 DTC Alerts. Then cut off my engine, this freaked me out. But after this i started it up still was blinking red and blue DTC ALERT, but drove and felt as normal. But still the weird noise coming from the passenger side engine compartment. The codes were in this order, P0340, P0345, P0606, P2106. I know that first two have to do with the camshaft or throttle body. I dont know what the last two are about. Any information with this problem would really help me out. Would these codes have to do with the noise when warming up? Please give me some advice on what to do. Thank you.
Rob
Rob
P0606
- Engine Control Module (ECM) Harness power supply circuit is open or shorted
- Engine Control Module (ECM) Programming
- Faulty Engine Control Module (ECM)
P2106
- Throttle actuator control motor is stuck open or closed
- Faulty Throttle actuator control
- Throttle actuator control motor harness is open or shorted
- Throttle actuator control circuit poor electrical connection
P2106
