Ticking noise
I have a 98 Ford F150 4x4 5.4v8 the engine was rebuilt by me about 2 years ago all new parts top to bottom. My truck makes a loud ticking noise coming from the passenger side of engine this is the list of items Ive replaced so far lash adjusters, back 4 lifters (that is where the noise is the strongest using a stethoscope),oil filter, changed the oil to 5w30, checked oil pressure 60psi nearly all the time, exhaust manifold gasket on that side. I have a link to a video I made that I posted on YouTube not any responses yet I need help PLEASE
here is the url :
here is the url :
Probably going to have to pull the cam cover on that side and see what's going on. It's not misfiring is it, - running on all 8 right? Sounds like the lash adjusters. They're hydraulically pump up by oil pressure and take up the slack between the cam lobes and the cam followers. If the lash adjuster isn't pumping up fully, (might be some crap in there), - there will be a gap between the cam follower and the cam lobe, causing the follower to 'bounce' around each time the cam revolves and depresses/releases it. Yea, pull the cover and have a look see, - before it gets worse.
Doesn't sound like timing components IMO. Maybe the oil deflector that's pinned to the inside top of the cam cover came off. Other than that, -it sounds like the L Adjusters.
so far we pulled the valve cover off and used hose to pinpoint the noise. it was coming from cam chain the guide/tensioner seemed loose we put pressure on the chain while cranking(coil packs unplugged) and the noise was gone now we start the teardown of the front of the motor.
J brew I have replaced all lash adjusters on that side and there was no difference in sound you said something about (might be some crap in there) where would that be ? And yes it is running on all 8 no performance issues what so ever I'm stuck.....
BTW, - They are CAM COVERS on the modulars. Use to be valve covers, way back when. That's pretty old school lol.
No coil packs on the 5.4L's, there never was. That's a 4.6L thing. 5fours use COP systems.
Since he posted on You Tube, he's probably counting answers and is going with the majority anyway or looking for one he likes most. He's not really interested in fixing it, since he hasn't confirmed already given good advice. So, I'm out as well.
WOW didn't know you guys take offense to so little info yes your right they are cop coil over plugs you got your gold star for today and yes it is a MOTORCRAFT pcv valve and yes I posted it awhile ago on youtube before stumbling on this website lastly I work for a living and cant be on this site for hours on end like some of you lastly yes I want to get this fixed
Your a shiny one. Who the watches You Tube ? I guess you do, - good luck with that. Don't affiliate us with your habit, it's a bad one for answers. Might as well lurk there. Somebody will most likely get it right, - not that you'll ever know lol.
So let me get this straight your upset with the way I look for answers or other ideas regarding my vehicle. Because I posted the video on you tube before coming here to listen to you cry like a 4 year old no one else is complaining but you JBREW. you don't like you tube don't watch the video then you don't have to be an as$hole. of course you like cookies.
Now your being and have been a smart ace about everything. That's real smart, your going places... Your attitude is really helping with your problem isn't it ? Think real hard about that.
If you were as smart as you think you would have read the part yes I did change the pcv valve and bought brand new plugs did I not respond to his reply right after do I have to say its a MOTORCRAFT too. maybe you as bright as you are should have watched the video
If you were as smart as you think you would have read the part yes I did change the pcv valve and bought brand new plugs did I not respond to his reply right after do I have to say its a MOTORCRAFT too. maybe you as bright as you are should have watched the video idiot
BTW, - who's doing the crying here?
Yeah, -
