help with missfire
Old Feb 3, 2013 | 05:32 PM
trev0424's Avatar
help with missfire
I had a missfire on cylinder
6 swapped out the plug and it was fine for about 30 mins. Then started missing again. Any suggestions?
Posted from F150online.com App for Android
Old Feb 3, 2013 | 07:24 PM
JCR 56's Avatar
What are we working on?
Old Feb 4, 2013 | 06:56 PM
trev0424's Avatar
97 f150 4.6
Old Feb 4, 2013 | 07:24 PM
JCR 56's Avatar
Put a new set of motorcraft wires on it, if they haven't already been changed.
Old Feb 4, 2013 | 08:36 PM
jbrew's Avatar
Yea, they do that with an ignition problem when you disconnect the battery. When it's a low grade sort of problem. They'll seem to run well for a short period and end up in the same rut.
Sounds like a coil pack short.
Packs are interchangeable, so swap from one side to the other to determine a coil problem.
Old Feb 4, 2013 | 11:36 PM
trev0424's Avatar
Just changed the plug wires. And the the rest of the plugs. Not missing as bad or as often. So just swap the packs and then what?
Old Feb 4, 2013 | 11:43 PM
trev0424's Avatar
And I put motorcraft wires on
Old Feb 4, 2013 | 11:45 PM
trev0424's Avatar
Unhooked the battery CEL still on
Old Feb 5, 2013 | 06:42 AM
JCR 56's Avatar
Swap the coil packs from one side to the other as jbrew suggested, and see if the miss moves.
Old Feb 5, 2013 | 10:30 AM
Frankenstein81's Avatar
You have to leave it disconnected for 10 minutes to reset the codes.
Old Feb 6, 2013 | 08:58 PM
trev0424's Avatar
Ok i reset the code and the cel stayed off for a day still missed every now and then. Cel came on again and now its number 3. Didnt swap the coil yet
Old Feb 6, 2013 | 09:41 PM
jbrew's Avatar
Probably just a bad mount/connection on 3.
Old Feb 6, 2013 | 09:51 PM
scurtis3893's Avatar
It could be even multiple coil packs bad. On my 4.6 I had to do 3 of them with in a coulple week's even if it only says that one cylinder. Another way to test the coil backs is to have someone put it on drive hold the break to about 2 grand when it starts to skip and unplug the coil packs one at a time. If u unplug one and the motor doesn't change as in pick up more skip then that's the bad pack. It's just a common thing with these motors. This technique may be dangerous but works.
Old Feb 6, 2013 | 10:01 PM
jbrew's Avatar
Yea but, they only have 2 coil packs. None of these trucks use 3.
Old Feb 6, 2013 | 10:08 PM
There should be individual coils on each plug also that go bad frequently. There is one per cylinder, should be I thing a number 10 socket to take its one bolt out. I will post an advance auto link of msd ones that will show what I mean.
