1ST F150, 98 5.4l lean codes
Old Dec 10, 2012 | 01:22 AM
  #31
mustang413's Avatar
glc, I have changed the fuel filter. Would the cats have to be removed to check for blockage?
Old Dec 10, 2012 | 09:41 AM
  #32
jbrew's Avatar
Originally Posted by mustang413
Okay, new problem, maybe a little more serious. Do anyone think it is fuel issue or a transmission issue? I have a feeling I am getting ready to lose my rear on this truck.
Is the truck shaking, difficult to keep on the road @ 50 mph or above?
Old Dec 10, 2012 | 10:31 AM
  #33
jbrew's Avatar
glc can answer that, -I'll just add that it sounds like you melted the cat cone sealing most of it up. That only happens when the vehicle has had misfire issues or someone ran Seafoam thru it.
Old Dec 10, 2012 | 12:23 PM
  #34
No, they can use an infrared tester and/or pull O2's, stick a gauge in the bung and check for backpressure.
Old Dec 10, 2012 | 09:15 PM
  #35
mustang413's Avatar
I know that I have not ran seafoam through it and have not had any misfire codes. I guess that I will have to find some time to get it to the muffler shop. jbrew, the truck does not shake or seem hard to steer over 50mph, it actually seems to track decent for its age and tire size the hill billy before me mounted. I am getting little leary of my new (used) truck. Sometimes it hesistates when I give it the gas from a stop sign or light. I am afraid I am going to lose/chase my *** on this truck.
edit: sorry jbrew, in the above post lose my rear end was figuratively speaking not literally sorry about that. I am just at a loss as to where to start to get this truck up to snuff.
Old Dec 10, 2012 | 11:41 PM
  #36
jbrew's Avatar
I know exactly where to start, that's what I was getting you prepared for earlier.
Rip off that intake and compression test. That's where you start with that one and right away, you'll know if it's worth doing with that engine.
You pass compression, then you start right there @ the intake gaskets and work up. They're good strong motors if it was taken care of. Right now you have problems, so you need to find out what's going on.
I've done it, there's little problems in a few places with one this old, not usually a big deal but they add up. you know....
Old Dec 11, 2012 | 09:01 AM
  #37
mustang413's Avatar
Does it matter if I was not pushing the od button when going up the slight incline while pulling the trailer?
Old Dec 11, 2012 | 11:45 PM
  #38
mustang413's Avatar
What should the psi for the cylinders be for the compression test?
Old Dec 12, 2012 | 04:40 AM
  #39
jbrew's Avatar
Yea, look to the link in my sig,-
Old Dec 12, 2012 | 06:16 PM
  #40
mustang413's Avatar
