Spark plug / COP parts ?
Old Nov 8, 2012 | 09:47 AM
Fleemanch's Avatar
I am getting ready to do my spark plugs and I want to make sure I am getting the recommend plugs.
1. I will use motorcraft as everyone says here. I believe the part number is SP479; is that correct?
2. Also, my truck has about 143k on it. Is it recommended to change the coils as well while I am in there? If so, what brand/part number is recommended?
3. Lastly, what do people torque (ft/lbs / in/lbs) the COPs to when reinstalling?
Thanks in advance!
Chris
Old Nov 8, 2012 | 03:10 PM
ParnAZ's Avatar
Affirmative sp479 assuming you have a 5.4L? Visteon coils should work fine or of course Motorcraft. 28 ft/lbs no anti sieze on the plugs. Just snug the coils they don't really need to be torqued way down.
Old Nov 8, 2012 | 04:00 PM
Do not overtorque the cop bolts, there is supposed to be some slop in the bushings. I'd say you wouldn't even need a wrench on them, a nut driver should be more than good enough.
I wouldn't necessarily replace the cops yet, but you may want to replace the boots. Make sure you use dielectric grease.
Rock Auto has boot/spring kits, and if you do wind up needing cops, search Ebay for Visteon DG508.
Old Nov 8, 2012 | 04:30 PM
Fleemanch's Avatar
Thanks you for the replies and the tips!
Old Nov 11, 2012 | 02:25 PM
jbrew's Avatar
The very best you can do as far as coils and plugs IMO:
Denso Iridium spark plugs
Motorcraft/Visteon coils
Granitelli Solid connectors. No springs.
