2004 Hum/Buzz noise while accelerating
Old Oct 16, 2012 | 03:32 PM
derik taylor's Avatar
Help! I have a 2004 f-150 Lariat 5.4 with 108,000 miles. For several months, I have been dealing with a annoying hum or buzzing noise only when I accelerate. There are alot of threads dealing with similar noises, but they all lead to different issues. I know that tracing noise problems can be tricky so I will try and paint a picture as best I can.
-It doesn't matter if engine is cold or warm.
-It hums while accelerating and will immediately stop when I let off the gas.
-It will start again when I press the gas.
-It will stop and go quiet when I reach my highest gear.
-The engine idles fine.
-It is not related to anything in the rear axle assembly including rear end, as
I have has all of this replaced recently and the noise is still present.
-I have checked the front wheels for play and they seem fine.
-I have had the transfer case and front diff fluids changed about 10k miles
ago.
Any help would be appriciated on this. I would love to have some sort of direction before taking it into a shop blinded.
Thanks so much,
Derik
Old Oct 16, 2012 | 05:22 PM
JCR 56's Avatar
Air intake noise?
Old Oct 16, 2012 | 09:42 PM
I had something like that my intake going into the fender had popped out.
Old Oct 17, 2012 | 09:49 AM
Hmm - leaves in the intake tube between the fender and air cleaner?
Old Oct 17, 2012 | 11:13 AM
Really, Air Intake? I was thinking it might be transmission or torque converter problems. i'll look into the air intake.
Old Oct 21, 2012 | 08:41 AM
enriched's Avatar
only does this with it in gear or truck in motion?
can you get it to repeat, in Park or Neutral in the drive way & slowly depress the gas like you would normally accelerating ?
Old Oct 21, 2012 | 08:50 AM
MTM Ford's Avatar
Put it in 4x4 and see if it stops.
When I changed the spark plugs in my truck I got a defective one and had a miss. When I'd accelerate it was hummin and buzzing just like you described. I could tell it was coming from the front end. When I put it in 4x4 it would stop. I'm assuming my problem was something to do with vacuum and the IWE. I changed that spark plug and haven't had an issue since.
I'm not saying you have a miss but it could be a problem with the IWE's.
Old Oct 23, 2012 | 10:57 AM
Update: It only does the noise when in motion( not revving in the driveway), 4x4 doesn't seem to matter, and pulling a load up a hill makes it worse i believe.
