2004 5.4L 3V plug swap preparation.
Old Sep 10, 2012 | 12:39 PM
dbhost's Avatar
My trucks miles are getting into the range where I need to worry about the plug change. I am considering doing a few things in the weeks prior to actually performing the plug change per the latest TSB I can find...
#1. I have SeaFoam by the gallon. I am planning on running a pint through each tank for a couple of weeks prior.
#2. Do the SeaFoam top end cleaning (suck 1/3 or so of a pint through the booster vac line, stop it, let it soak for about 20 minutes, and then let the neighbors enjoy the smoke show...
I have months to go before this is needed, so I was wondering if maybe doing the top end cleaning a couple of times would improve my odds of getting all the crud out and making the extraction a fairly clean process.
Old Sep 10, 2012 | 03:10 PM
averagejoe074's Avatar
maybe somebody will correct me if I'm wrong...but I've heard sea foam is hard on the cats?..seems like I remember alot of people saying to run techron to help clean up the carbon deposits..
Old Sep 10, 2012 | 03:16 PM
Sea foam is junk.....
You should use chevron techron, berrymans b12, or gumout with regane....
Old Sep 10, 2012 | 04:08 PM
JimAllen's Avatar
I've not seen Seafoam used successfully on this but that doesn't mean it won't work... but you'll be the guinea pig, however. Lots of good reports on Techron and that seems a good bet. Your choice. If you go Seafoam, please tell us one way or another.
Old Sep 10, 2012 | 05:01 PM
dbhost's Avatar
Interesting.... When I first got the truck everyone was swearing up and down that Seafoam was the magic elixir... My how time changes things...
Old Sep 10, 2012 | 08:12 PM
DYNOTECH's Avatar
I personally wouldn't go through all the trouble and wouldn't sweat the plug change either. If you have the Lisle tool or can get one this job is not that big a deal in my opinion. Just follow the Ford TSB using the Motorcraft cleaner they suggest just prior to removal and even if the plugs break its easy to extract them. Just take it slow and follow the directions. Good luck
Old Sep 11, 2012 | 02:14 AM
Put Techron in the gas, and don't put anything down the brake booster line. Keep your Seafoam for your small engines and stuff.
