rear swap 8.8 to 9.75
Old Aug 22, 2012 | 06:09 PM
Bama Boy85's Avatar
I have an extra rear I was planning on building into a fully locker set up but never did. its the whole set up. only downside is it came w 3.55 open diff. What do you think?
Old Aug 27, 2012 | 04:39 PM
IntRiniTy's Avatar
your in VA and the whole purpose is to get the LS.
aprreciated though
i need the driveshaft anyway, might as well do it all in one shot
considering getting the tranny 4r75 too. maybe they could do me a deal. then ill have a back up for turbo build. i dont think my TC or tranny going to last that long with FI, considering it iwas designed for a 4.6. id like to get a spare block too
first things first, i need LS. nothing s worse then a one wheel peel!!!
Old Oct 10, 2019 | 12:15 AM
2BEERS's Avatar
07 4.6 F150 4x4 STX 8.8 10-Bolt SWAP TO 07 9.75
Originally Posted by jbrew
He's probably thinking that because only the 5fours had the 975. That doesn't matter.
I'm thinking the pinion is longer, so you'll need the shaft ? Not sure, Something has to be... - To accommodate the larger ring gear. Additional length is needed to center with it, right.. Regardless, I'd need to either look up R&P sets and hope for a measurement or get a shaft measurement.
The "New" Junkyard 07 9.75 373 W/80k miles, Bolted Right into my 07 4x4 4.6 !
Had To Shorten Existing 4.6 Driveshaft Little over an inch....Sorry didn't record how much.
The 4.6 Uses 3-Leaf Spring Pak-The 5.4 USES 4-Leaf Spring pak* Left the 4.6 3-Leaf Springs in Since Have
Monroe Load Leveler Shocks. The 9.75 Uses 18" Wheels-Larger Axles BUT* SAME 6Lug Pattern on both. So, just used my 17" Stock Wheels & Brakes. Truck Really Hauls The Mail Now. It Seems? Just uh Little Quicker? These Ford 9.75 rearends
Are Being Compared To The Famous Dana 60!! I Think They're Rt* ...only weak spot compared to Dana=
Axle tubing thickness Ford=.180"--Dana=.250" if this Old guy remembers rt. So, Since I'm probably gonna be buried in this thing....can't afford new....I Will Just Turn it Into a 5.4 ! Research reveals, if u swap SAME YEAR 5.4 With Or Without Corresponding Replacement R75 Tranny-*WITH ALL THAT YEARS SMOG DEVICES=CA DMV Will Sign off on it And Test Accordingly Thereafter.
Food for Thought. Only problem I have run into is The ABS dash-Lt is on=no abs...hmmm..Any Suggestions? THNX ALL-
