How hard is it to change starter on '07 4.6?
Old Apr 19, 2012 | 01:26 PM
aggieben04's Avatar
I think I have some stripped gear teeth on my starter motor because every so ofter, I'll get this horrible grinding noise when starting the truck. The starter itself isn't too expensive but how hard is it to install? Where is it located on the engine? Thanks.
Old Apr 19, 2012 | 01:41 PM
nu-supercrew's Avatar
sounds like it's not disengaging. Bendix spring is prob bad. Do starters still have bendix springs? I don't know if it's an easy job...
Old Apr 19, 2012 | 02:07 PM
here's a video....its for a '97 but the starter is still the same setup and in the same spot on your '07....
http://www.youtube.com/watch?v=p4dDKaWOVQs
Old Apr 19, 2012 | 02:56 PM
Here is the link from the how to section
https://www.f150online.com/forums/ar...l-starter.html
Old Apr 19, 2012 | 07:05 PM
jbrew's Avatar
Very Simple, with the correct extension and air ratchet.
Old Apr 19, 2012 | 07:07 PM
jethat's Avatar
I'd worry more about the flywheel ring gear.
Old Apr 19, 2012 | 07:08 PM
aggieben04's Avatar
Yea that's my concern too. Should I pull the starter off first and inspect the gear on that and then if the gears are fine I should assume the flywheel is jacked up and vice versa?
Old Apr 19, 2012 | 07:14 PM
jethat's Avatar
There is an inspection plate. I would take it off and manually turn the engine. If thats bad the tranny has to come undone to get it out..
Old Apr 19, 2012 | 07:26 PM
jbrew's Avatar
Make sure nothings bent or missing teeth. I haven't seen that to often or at all with these. Pre 07, yes..
