2002 4.6 auto ( missing under accel ,but not all the time). Help!!
Old Apr 14, 2012 | 12:56 AM
BASS ASSASIN's Avatar
Exclamation 2002 4.6 auto ( missing under accel ,but not all the time). Help!!
Hello, had my plugs changed at 100,000 miles
At 102,000 I went out to truck one morn and all t would do is spin over ,
Tried t 2 times, on third time it cranked ran great for 2 weeks then all of a sudden one day, it started to miss under accel. Then at idle, it,ll do it couple of days then, it'll run good couple days, so I took it in to shop, it pulled a code
Po230. Fuel pump circuit open? Replaced relay, didn't fix it, replaced fuel filer, didn't fix it either, the fuel pressure is at minimal 28 lbs.
Does all this lead to a new fuel pump? I love the truck but getting sick of this problem, ( when I cut the key on, it doesn't sound as loud as it once did)
Fuel pump that is,
What's your opinions?
And is it easy to drop tank and replace?
Thanks for reading.
Old Apr 14, 2012 | 01:12 AM
P.S. The machine he ad hooked to my truck was show 3 different cylinders miss firing due to it running lean, it gave him indication that it might be low fuel pressure causing it.
What you think?
Old Apr 14, 2012 | 08:20 AM
c.frank47's Avatar
The fuel pump would be my first guess, pressure seems low.. According to others it is easier to drop the tank than to lift the bed to change the pump
Old Apr 14, 2012 | 10:44 AM
Alex_4.2L's Avatar
What kind of plugs did you use?
Old Apr 14, 2012 | 02:29 PM
Well just spent $225 on new fuel pump assembly, installed it cleared codes and went on test run, it run smooth, then after 2 miles started is missing again, i checked codes again and it was p1000 not enough driving time to get a code, so what else? You can floor it and it runs great, ease into throttle and it runs great give it 3/8 of the pedal and it misses, I have no clue
Plugs were changed and went back with motor craft plugs,
Old Apr 14, 2012 | 05:10 PM
What's your fuel pressure now? Does it go up about 5 psi when you disconnect the vacuum line from the FPR?
You may have one or more bad coils. Did you use dielectric grease in the boots when you changed the plugs?
Old Apr 14, 2012 | 10:49 PM
I paid a shop to change my plugs, not sure if he used the grease or not, were do most on here buy the coil packs at and whats a affordable brand,
eBay has 8 coils for $98.00 sound to cheap?
Old Apr 14, 2012 | 10:56 PM
c.frank47's Avatar
New at autozone are 50 each. I've beeen running Grannettelli hot streets for about 2 yrs they're 250.00 for the set. Just lost one of them about a month ago and put in a stock one, I'm going to change all of them back to stock as they go bad.
Old Apr 14, 2012 | 10:57 PM
jbrew's Avatar
Yea, they are cheap, BUT can and have gone the distance...
No coil packs on that truck, - just coils are used with COP ignition systems.
The best route is to use those Hungary coils, -Visteon/Motorcraft. Sold on eBay and Amazon. I believe they are $160-$180 for a complete set. Just get the correct ones.
These are original OEM's. They also sell new Motorcraft tagged sets here and there now, you have to look around, but they're out there.
Old Apr 14, 2012 | 11:02 PM
jbrew's Avatar
That was ballsy lol. Hey, you got two years out of them without a prob. - That's good for those!
Old Apr 14, 2012 | 11:38 PM
I had already bought some on eBay before I read your post sorry , I got the coils from global automotive, 10 coils, 79.98 , lifetime warranty, how often do these go out?
They had great feedback, and I searched and a lot of people on this website have used them, I,m short on cash , so I hope they work!
Old Apr 14, 2012 | 11:40 PM
c.frank47's Avatar
Yeah thats what Terajerame told me when I put them on, he dang near ran me off he was so hard on me
Old Apr 15, 2012 | 12:00 AM
jbrew's Avatar
Yea Jerame can get that way, - we all can lol. But he knows what he's talking about, -a good guy actually.
Old Apr 15, 2012 | 12:02 AM
jbrew's Avatar
For some, soon. For others, like me. I installed my Globals back in 05. Never had a problem. Just install them right the first time, - they can't handle much abuse.
Old Apr 15, 2012 | 12:06 AM
c.frank47's Avatar
I believe you, I started lurking his post after that and noticed a lot of folks followed his advice. I'm new to these mod motors but I haven't got any bad advice from any of ya'll
