Please help
Old Mar 31, 2012 | 12:56 AM
Mr Nunn's Avatar
Please help
I just got a 2002 f150 and I recently helped a friend get out of some mud causing my truck to get muddy as well. After I cleaned everything under carriage and all I started to hear a dog whistle like sound coming from the car and I don't thing it is the belt or transmission because I had them checked out right before I bought it and they said it was in perfect condition does anybody have or had a similar problem and knows any way to help?
Old Mar 31, 2012 | 01:01 AM
1997 lariat 4.6's Avatar
Where on the vehicle? Motor, tranny, 4wd? Mine just rusts off the manifold flange bolts.
Old Mar 31, 2012 | 01:17 AM
Mr Nunn's Avatar
Seam like motor 2wd but not sure cause pitch is so high it is hard to follow
jethat's Avatar
probably got some crap on the belt. Make sure its clean and dry.
Old Mar 31, 2012 | 01:56 AM
x2 on stuff on the belt, just clean it up and you should be good, that is if it's your problem...
Old Mar 31, 2012 | 09:15 AM
jaws12's Avatar
One thing about mud, it gets everywhere. Your pulleys could have sand in the grooves.
Old Mar 31, 2012 | 09:51 AM
do NOT pressure wash your engine to clean the mud and dirt off!
Old Mar 31, 2012 | 09:59 AM
jethat's Avatar
A hose is good for mud amd a mild soap.. Dont get the top of the engine wet..
Old Apr 1, 2012 | 05:27 AM
jbrew's Avatar
Make sure the air box didn't clog. The inlet maybe,- inside the wheel well. And if it by chance got wet up in there, - the filter can clog as well.
